D15b2 low idle
Old Jan 8, 2012 | 08:51 PM
SGBR92's Avatar
Default D15b2 low idle
Ok so I know this topic has been covered a million times and I've used the search feature. I have a D15b2 in my 91 crx and it has a low idle. I've cleaned the IACV twice its still there although before I cleaned it I had Jumping Idle. I checked to make sure I don't have a fast idle and I don't so I have no idea what the problem could be. I also bled the air. Could it been that my idle is set too low or a map sensor. I'm not getting a check engine light. Sorry I am still learning about Honda's so If I didn't explain it very well please forgive me. By the way its been converted to MPFI.
Also I didn't swap the engine It was in the car when I got it. I'm looking to put in a d16z6.
For some reason the Image isn't showing on my screen if it doesn't pop up just right click the small box and open in a new tab.
Old Jan 9, 2012 | 04:22 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: D15b2 low idle
Turn the idle screw up on the throttle body...
You didn't search too hard - first link the Google pulled up...
http://ef-honda.com/ben/Badidle.php
Old Jan 9, 2012 | 03:31 PM
SGBR92's Avatar
Ah Thank You N3va3vaSatisfi3d. Although when I was speaking of searching the topic I meant I had searched on H-T and hadn't found anything other than what I had tried. As I stated I'm still learning I am still definitely a noob. But like I said thank you.
Old Jan 9, 2012 | 03:45 PM
SGBR92's Avatar
Just read your Sig and realized how true it was. Definitely one of the funniest I've read.
Old Jan 9, 2012 | 03:48 PM
DO IT ON ALL FOURS
You are welcome and I am mean.
You will find the Honda-Tech search feature turns up a LOT of useless results. Your best bet is to type it in the Google and go from there. There is TONS of information but it's spread out everywhere. Too bad nobody maintains the FAQs anymore... There is still useful information to be had though:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
Old Jan 9, 2012 | 03:52 PM
codybuRr's Avatar
teach the noobs well, master jedi
Old Jan 9, 2012 | 05:36 PM
SGBR92's Avatar
Haha that's perfect.
And that FAQ will probably become my homepage.
Davesmit
Mar 24, 2019 11:27 AM
vodkaTM
Jul 31, 2009 09:08 AM
99d-series
May 18, 2009 04:51 PM
minner
Oct 8, 2006 01:30 PM
