Matching Engine and Trans Serial Numbers
Old Oct 8, 2002 | 01:22 PM
VTECPWR's Avatar
Default Matching Engine and Trans Serial Numbers
Help, I have become parinoid that the body shop I left my car at for a week swapped transmissions on me. Should the Serial Number off the Engine block match the one on the Transmission (mine do not)? If not is there any other way to tell if the trans is the original?
TIA
[Modified by VTECPWR, 2:23 PM 10/8/2002]
Old Oct 8, 2002 | 01:29 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Matching Engine and Trans Serial Numbers (VTECPWR)
The serial number should match up ith the block and head (@ least on japanese swaps), unless this tranny has been replaced (Or mabye the case)???
Old Oct 8, 2002 | 01:30 PM
sneakychaos's Avatar
TIA
The VIN's should match. Unless they went through the trouble of taking yours off the old one and re-pressing it into the new transfer case.
EDIT:
[Modified by sneakychaos, 5:30 PM 10/8/2002]
Old Oct 8, 2002 | 01:35 PM
Tommy_Gunns's Avatar
Sounds like it is time to seek legal actions or "Kick his *** sea bass".
Old Oct 8, 2002 | 03:07 PM
VTECPWR's Avatar
Default Re: Matching Engine and Trans Serial Numbers (Tommy_Gunns)
This is the serial number I am talking about right now. Not the VIN. The VIN on the block is correct. But the only numbers I could find on the transmission was the serial number, and looking in the manual I actually think it is correct that it is different than the serial number on the block. I am not sure where the VIN on the trans is located, I have not had a chance to climb under the car yet and look from that angle.
Any advice in verifying the transmission is the orginal would be apperciated.
Old Oct 8, 2002 | 03:19 PM
Ferrell's Avatar
if the vins match up you should be ok?
Old Oct 8, 2002 | 03:27 PM
VTECPWR's Avatar
Default Re: Matching Engine and Trans Serial Numbers (Ferrell)
Well, I should be ok if the VINS, match. Assuming they just did not pull the vin plates off and put them on the other trans.
Old Oct 8, 2002 | 04:18 PM
VTECPWR's Avatar
Well, I have to come to the conclusion that I am just being parinoid. I jacked up the car and spun one tire, the other rotated in the opposite direction. I can't imagine that they would swap the trans with another with an LSD. I can only attirbute the difference in the way the car seem to be running to the loss of ~50lbs and a resetting of the ecu.
Old Oct 8, 2002 | 07:49 PM
t's Avatar
t
The bolts used to attach your VIN plate are Special HONDA bolts (and are marked by HONDA). Cannot be bought anywhere.
Old Oct 8, 2002 | 10:10 PM
I think I know your problem, you are comparing the VIN on the tranny housing to the block serial number above the B18C5 stamp.
The VIN on the engine block is on a green tag hidden behind the header and looks just like the tranny VIN.
fungus mungus
Apr 22, 2011 09:22 PM
CARMA_626
Dec 12, 2010 04:33 PM
junior_tm
Mar 30, 2009 06:07 PM
South Bay Surfer
59
Aug 12, 2003 07:21 PM
filetofit
Oct 1, 2002 08:36 PM
