1st gen b16a speedo swap help
Old Jan 8, 2012 | 05:12 PM
91ricer's Avatar
Default 1st gen b16a speedo swap help
So I have a 91 hf with a 1st gen b16a and My speedometer is not hooked up because from what i see it has a electronic speed sensor which IM assuming is jdm. I want my speedometer to work as its annoying to not have one. Now I know for vtec to engage you need to have the vss hooked up. So basically what im worried is. If i install the mechanical vss cable to the speedo vtec wont kick in when IM in the "spirited" driving mood. So I searched that i need to take the speedo out put signal cable and wire it to the ecu. So instead of reading off the tranny is reads off the speedometer. Now im a little confused so if some one can point me in the right direction that would be great thank.
Old Jan 8, 2012 | 06:18 PM
zrickety's Avatar
Default Re: 1st gen b16a speedo swap help
Get the vss from a DA (90-93) integra.
Old Jan 9, 2012 | 04:25 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
The more you talk the more you confuse yourself... Just get a '90-93 Integra Mechanical Speed Sender and the rest will take care of itself (you won't throw a code 17 anymore). Simple as that.
Old Jan 9, 2012 | 01:00 PM
91ricer's Avatar
Its not throwing a code now. Would it be normally.
Old Jan 9, 2012 | 01:44 PM
DO IT ON ALL FOURS
Ah, whoops I read that wrong. Anyways, they must have wired up the electronic VSS so VTEC would work. You could always just swap in a "DC" (94+ Integra) cluster as most due. It is typically desirable to put in an electronic VSS. IF it wasn't wired in properly then you surely would be throwing a code.
The other option is to get a mechanical VSS and swap it in; then rehook-up the cable. After that you can hope they didn't hack the wiring too bad so the pulsar still works on the gauge cluster.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-put-integra-gauges-88-91-civic-2941126/
Old Jan 16, 2012 | 01:29 PM
91ricer's Avatar
IM going to be totally honest the integra cluster in a crx looks like **** , it doesnt even fit right and the gas gauge is half cover by the trim.
Old Jan 16, 2012 | 01:30 PM
91ricer's Avatar
wouldnt it just be easier to swap in a jdm sir cluster?
JustEFit
Aug 19, 2013 11:49 AM
Jay.D.Em!
Mar 24, 2006 11:54 AM
B16aSir2
13
Feb 7, 2006 10:13 AM
r7
Jul 21, 2002 03:59 PM
topsekret
Mar 6, 2002 10:06 PM
