Stainless oil line feed & drain kit w/ firewall relocation -new- stealthmode performa
Up for sale is a complete turbo stainless steel oil line feed & drain kit with firewall relocation
NEW - never used
made by Stealthmode Performance
-3 AN stainless steel lines (4ft long & 17 inches long) and -10 AN stainless line 14 inches long
The short thin length of stainless line runs from the back of the block to the firewall where the T fitting can be mounted. The longer length of stainless is then run from the T fitting into the turbo. The other outlet from the T fitting can be used for an oil pressure gauge.
This is all of the necessary fittings including 2 dual outlet block fittings, T fittings, AN fittings along with install instructions (I forgot to include the drain flange in the photos, but I have that as well - only the bolts to mount the drain flange are shown)
$110 shipped
NEW - never used
$110 shipped
http://hondamarketplace.com/showthread.php?t=2689357
8. When you are finished with your thread and parts have been sold, please mark the thread as such and use the "REPORT" button
to have the thread closed. We DO NOT delete threads.
Please remember this next time.
Thanks!
