2 cels and 2 sensors not connected help?
Old Jan 8, 2012 | 02:49 PM
blacktibby07's Avatar
Default 2 cels and 2 sensors not connected help?
first off my car is a 98 civic auto trans with mini me swap... i managed to swap ecu, full engine harness and head...
ok so im throwing 2 cels p0141 and p0325, which are secondary o2 sensor and knock sensor...
i know im throwing p0141 cause i no longer have a hook up for a secondary,anyone know where to pin in ecu or bypass?
knock sensor ive disconnected and hooked back up no luck getting it to work, is there a bypass for it?
i also have 2 connectors hanging loose above oil filter under intake manifold...
not sure what there for?
here they are...
Old Jan 8, 2012 | 03:06 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 2 cels and 2 sensors not connected help?
How many pins are there in that round plug? If its one that is your knock sensor wire.
Heres the second O2 wiring
http://ff-squad.com/wp/?p=395
Old Jan 8, 2012 | 03:35 PM
It has 2 pin ins, and I already have a connector hooked up to knock sensor
Old Jan 9, 2012 | 11:02 AM
bump any idea on these pics? what sensor connectors?
Old Jan 9, 2012 | 01:49 PM
delsolo95's Avatar
it would help if you gave us the wire colors.
the first pic could plug into any sensor since honda engines use that plug for numerous sensors. the second pic looks like the vss or iacv for auto trans vehicle
Old Jan 9, 2012 | 03:36 PM
the blue red round one is starting to look like knock sensor for my research but I have a zc block and there's not a spot for knock sensors on them.... Don't know what ill do bout it, the other hookup is lookin like crankshaft sensor which I bypassed to get rid of... No luck for finding knock sensor bypass yet...
Old Jan 19, 2012 | 04:08 AM
Found bypass with piezo transducer, works
Dstaks716
Oct 16, 2010 09:07 PM
97blacklude
Jan 31, 2009 09:56 AM
EG civic
Jun 17, 2006 10:05 PM
bb4socal
Feb 25, 2006 03:46 PM
