How to install manual steering rack in 94 del sol?
Old Jan 8, 2012 | 11:25 AM
77chev7777's Avatar
Default How to install manual steering rack in 94 del sol?
Could anyone give me the procedure to remove and install a manual steering rack? I may have to do this, thanks in advance
Old Jan 8, 2012 | 12:12 PM
NotAJDMFanBoy's Avatar
Default Re: How to install manual steering rack in 94 del sol?
it's easier to convert the power rack to manual, and you have a faster gear ratio. You need to either cut two of the lines and loop them together after flaring one to make a sort of barb fitting, or remove two lines and use metric to AN adapter fittings. I think the fittings are 14mm x 1.5 and 16mm x 1.5, but check first.
To remove the rack, you pretty much have to either pull the motor or the subframe with a power rack, or so I have read. Other than that, just unbolt the universal joint on the column, the two bolts on the drivers side, the D bracket on the passenger side, and pop the two tie rod ends off.
Old Jan 8, 2012 | 01:51 PM
HondaPartsHero's Avatar
Technical Hero
http://www.hondacivicforum.com/forum...0-civic-81749/
http://www.ej8squad.com/thread-12402.html
http://civic-eg.com/viewtopic.php?t=7198
Old Jan 8, 2012 | 03:59 PM
77chev7777's Avatar
Thanks guys but i'm not talking about the loop mod. I already have a manual rack and I believe it is going bad. The car darts from the left and right when cruising. I need a write up on how to remove and then install the new rack. TIA
Vcarey21
Oct 17, 2014 08:28 AM
DelsolVted
May 22, 2011 08:32 PM
XxslayerxX
Feb 17, 2004 08:55 AM
BlackFrog
Sep 13, 2003 11:04 AM
tz-devil77
Feb 5, 2003 12:12 PM
