headgasket or something else?
Old Jan 8, 2012 | 05:40 AM
accordin 2 me's Avatar
Default headgasket or something else?
im waiting for a friend to bring his compression tester as we speak and ill leakdown after depending on results. Anyway its a b20 i see white smoke when its cold but im running straight pipe with no cat. i see water coming out of the pipe but with the temp i think its normal. car sputters and hesitates a little . heres the thing tho. no mixed fluids at all, car stays below half with temp, but im burning coolant on my fourth cyl. umm help?
Old Jan 8, 2012 | 05:42 AM
Default Re: headgasket or something else?
a friend was saying hes heard of this happening because of intake manifold gaskets failing.
Old Jan 8, 2012 | 05:45 AM
91STDFLOW's Avatar
White smoke is water, or moisture in the pipe, and since your in florida and its been getting colder a cold start would do that, does this continue after driving for a while or does it go away?
Old Jan 8, 2012 | 06:08 AM
i have not driven it more than 3 blocks since i noticed my car acting up. ill test it today.
Old Jan 8, 2012 | 06:12 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Key words in previous post by OP - it "sputters and hesitates"...
Yes, this is a possibility (since obviously the intake port is right next to the coolant port).
Old Jan 8, 2012 | 06:22 AM
honestly after adding up my reciepts that i have from JUST the b20 im already at $4162.54. thats not including converting the car to manual when it was a single slammer. i would say my 200 dollar car has me at almost 4500 dollars in 16 months. im so tired of it. I took the fouled plug to a few places and they all said i was burning coolant and i know that its true. ill see today i guess if its the intake.
/rant
Old Jan 8, 2012 | 08:32 PM
intake manifold gasket, dirty injector nets and dirty fuel filter. its fixed
Old Jan 9, 2012 | 03:36 AM
DO IT ON ALL FOURS
Glad to hear you got it fixed. Next time, show me a better picture of the spark plug from a top view showing everything and I could have pin-pointed it better for you. At least I helped you get it on the right track though.
integra_101
Jun 18, 2013 03:42 AM
civic addict
15
Sep 12, 2010 04:09 AM
eg4metodrive
Feb 20, 2006 05:05 PM
EK9 BEEZLER
Apr 21, 2005 09:26 AM
buck02
May 28, 2004 09:12 AM
