92 EG8 Exhaust - replacing cat with a pipe
Old Jan 6, 2012 | 12:27 PM
Simplypinoy's Avatar
Default 92 EG8 Exhaust - replacing cat with a pipe
I have a catback and headers on my 92 EG8 and my catalytic converter rusted and snapped. So is it ok if I just put a pipe in place of my catalytic converter.
Old Jan 6, 2012 | 12:29 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 92 EG8 Exhaust - replacing cat with a pipe
Do you have to pass emissions? If so then no.
Old Jan 6, 2012 | 12:30 PM
BryanM.'s Avatar
Resident Gearhead
Won't hurt you car but it's illegal.
Old Jan 6, 2012 | 12:36 PM
I don't have emissions, here they only test OBD2 they dont put the cars on belts anymore.
Will i have any problems with the o2 or CEL? I don't know much about exhaust systems.
Old Jan 6, 2012 | 12:47 PM
jbpnoman's Avatar
If you're running OBD2, and have no catalytic converter, it will probably throw a CEL from your secondary O2 sensor. If you want to run a straight pipe without the constant CEL, you can get an O2 sensor simulator.
Or if you want to do it the right way, Magnaflow makes universal cats you can weld in, and they're relatively inexpensive. When I replaced mine, it was cheaper to have the shop cut the flanges off my test pipe and weld them onto the Magnaflow than it would have been for a direct replacement. They also flow fairly well.
Old Jan 6, 2012 | 12:52 PM
I'm running obd1 and just looking for a cheap alternative. Is it ok if i just use the pipe and dont get a new cat?
APAem1
Jul 20, 2010 05:58 AM
MaGoodc2
Feb 18, 2006 02:53 PM
SubTitle
10
Oct 18, 2005 09:33 PM
Azn Kenny
Oct 11, 2005 05:14 PM
typesguy
Jul 22, 2004 02:08 PM
