Help H22 ek transmission
Hello
I Just ended my h22 swap in 96 ek...
So my problem is that i have not LSD I think best way is to use M2b4 transmission but when i bought my axles they told me that it`s not working for LSD transmissions. can you help me please?
If i will change trans and install M2b4 witch axles can i use?
and what a difference between LSD and NON LSD axles?
and another question can i use B16 or B18 transmission and what do i need to modify?
Re: Help H22 ek transmission
I have the same question regarding the LSD axles and non-LSD axles. I will start researching it more when I have the money to actually go with an LSD transmission though.
B series transmission with H motor is H2B. Research what is needed. From what I have priced out, it is not a cheap upgrade.
