What are these two holes on D16 block?
Old Jan 6, 2012 | 04:52 AM
Fnix's Avatar
Default What are these two holes on D16 block?
Back of the block
Old Jan 6, 2012 | 04:54 AM
jbpnoman's Avatar
Default Re: What are these two holes on D16 block?
The green one is your oil pressure sensor.
Old Jan 6, 2012 | 05:13 AM
BryanM.'s Avatar
Resident Gearhead
Would be nice if you told us which engine it is. Since I don't see a spot for a knock
sensor, and you say it's a D16, I guess it's a D16Z6 (or whatever they call it in
Germany).
And jbpnoman is right, the green sensor is the oil pressure switch.
And the other hole is not used IIRC, someone correct me if I'm wrong here.
Old Jan 7, 2012 | 08:33 AM
shawn8772's Avatar
Icon4 Re: What are these two holes on D16 block?
pic of my Y8
My block has a plug in the 2nd slot in question. The Z6 in my car is the same way also.
Old Jan 7, 2012 | 10:24 AM
Wrona's Avatar
what they said for the green one you usually replace that when going turbo for ur turbo gauge and the other one isnt that to drain the block as well?>
Old Jan 7, 2012 | 10:25 AM
grumblemarc's Avatar
The Grumpiest
Actually you just tee off of it. It doesn't actually get replaced.
Old Jan 7, 2012 | 10:28 AM
Wrona's Avatar
oh my friends replaced his cause it came with his gauge
Old Jan 7, 2012 | 11:12 AM
H22AFerio's Avatar
Is that a d16y8? its sitting right up against the cylinder like its a hole for a knock sensor or somthing? :UPDATE:Yup its a knock sensor The D16y8 came with a knock sensor and a crank position sensor and the D16Z6 did not so Im assuming thats a D16Y8. but its not in the same location as yours on your block so im a little confused??
Old Jan 7, 2012 | 10:57 PM
numberone's Avatar
Green one is a oil pressure switch. The other is unused. Obd0 block.
Old Jan 7, 2012 | 11:34 PM
HondaPartsHero's Avatar
Technical Hero
Pretty sure it's Z6 block. The OBD0 block actually has threads in the second hole for the fan switch. See this link for comparison
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-d16z6-block-d16a6-head-2754616/
Old Jan 8, 2012 | 03:46 AM
BryanM.'s Avatar
Resident Gearhead
Same here, or the European equivalent.
Definitely not a usdm D16Y block.
Old Jan 8, 2012 | 10:39 AM
H22AFerio's Avatar
Yeah the block does look a little different from a US block...
Old Jan 8, 2012 | 10:42 AM
EvelAndy's Avatar
I believe theyre for knock and oil
Old Jan 8, 2012 | 10:45 AM
Wrona's Avatar
well OP is from germany but they also have the z6 in europe so idk.. would help if op responded
Old Jan 8, 2012 | 11:02 AM
H22AFerio's Avatar
me too..
Old Jan 8, 2012 | 02:07 PM
Technical Hero
I think he may have borrowed the pic from google
https://honda-tech.com/forums/forced-induction-16/stock-oil-cooilng-d16-block-2820019/
dls_tech
Dec 11, 2010 07:36 AM
bb6guy
Oct 25, 2010 04:27 PM
Charlie Moua
Mar 10, 2010 02:36 PM
600_Double_R
May 28, 2006 08:30 AM
crashtest Sonny
Aug 26, 2003 03:11 PM
