can't find 99 EX CEL plug
Old Jan 5, 2012 | 08:03 PM
twotonecivic's Avatar
Default can't find 99 EX CEL plug
so i have a cel on the dash and i'm tryin to get the b16a2 running correctly in my 99 ex. I can't seem to find the plug by the ecu to jump for a code. i know the 99-00 ex harnesses are different from all the other ek harnesses but i expect that the plug would be there. you don't have to tell me where it's located because i have done this before. the only one i've found is the obd2 port under the d/s, but the car is converted to obd1. i just wanna know if it's even there before i take the glove box out and go digging for a plug that's not there. thanks in advance!
Old Jan 5, 2012 | 08:37 PM
Wrona's Avatar
Default Re: can't find 99 EX CEL plug
it should be right next to the ECU..
Old Jan 6, 2012 | 10:22 AM
sde780's Avatar
It's blue, should be right above ECU
Old Jan 6, 2012 | 06:48 PM
i know wat it looks like and where it "should" be otherwise i wouldn't be asking this question
Old Jan 6, 2012 | 06:51 PM
redm3turbo's Avatar
obd1....i think the plug is brown....itd be next t o the ecu regardless tho
Old Jan 6, 2012 | 08:29 PM
sde780's Avatar
1. Is the cabin harness converted to OBD1?
2. If you know "wat" it looks like and where it should be, why don't you just find it?
3. You mentioned taking the glovebox out, which tells me you DON'T know where it is
Depends on what he means by "converted to obd1". If he's just using a conversion harness at the ECU the plug will be where it was stock.
Old Jan 7, 2012 | 06:25 AM
Former User's Avatar
Remove the passenger kick panel. It branches from the main wire harness above the ECU. It may be inserted into a green or blue rubber holder. Have you looked at the pictures in the CEL sticky?
03em2k20
Engine Management and Tuning
Mar 20, 2014 05:17 PM
Jonathan_ED3
Jun 23, 2012 12:40 PM
nappyracing001
Aug 16, 2010 05:41 AM
new_climber
Sep 15, 2009 09:22 PM
dc2inms
Nov 1, 2003 11:57 AM
