EG6 or EK9 rear camber kit
Old Jan 5, 2012 | 04:17 PM
9tailsfox's Avatar
Icon2 EG6 or EK9 rear camber kit
hello again. can someone explain how these rear camber kit work. I know front camber kit can be adjust +/- for track use better cornering. but these rear camber can be adjustable? Thank you
Old Jan 5, 2012 | 04:19 PM
grumblemarc's Avatar
The Grumpiest
Default Re: EG6 or EK9 rear camber kit
Stop it. Just stop it. You don't need a camber kit.
Old Jan 5, 2012 | 04:22 PM
9tailsfox's Avatar
=.=' can explain at least how it work? r u a guardian here ioi
Old Jan 5, 2012 | 04:24 PM
The Grumpiest
Google.
http://www.slickcar.com/info_what_is_camber.asp
Old Jan 5, 2012 | 04:26 PM
9tailsfox's Avatar
=.=" damn you caught me again
Old Jan 5, 2012 | 04:36 PM
Wrona's Avatar
IT makes ur car JDM y0
Old Jan 6, 2012 | 03:23 AM
The Grumpiest
Here's a better link.
https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
Old Jan 6, 2012 | 03:41 AM
jbpnoman's Avatar
How do they work? You loosen the locknuts, rotate the adjustment arm, then tighten the locknuts, adjusting the camber of your wheels. Do you need them for street driving? No. Do you need them for track driving? They wouldn't hurt, but you'd be better off becoming a better driver before you worry about the effects of a degree of camber.
Old Jan 6, 2012 | 04:19 AM
The Grumpiest
I think he wants to know more along the lines of their function.
Old Jan 6, 2012 | 04:46 AM
jbpnoman's Avatar
Conciseness is important, then.
To the OP: Yes, front camber can be adjusted for handling, but rear camber, for track use, has just as much effect on handling. You can read more about the effects of front and rear camber here.
I still stand by my statement that before anyone spends money and time fine tuning rear alignment, they should spend more time on the track and on the books becoming a better driver. The best tuned alignment isn't going to suddenly make you Sebastian Vettel.
blk94gsr
Suspension & Brakes
Feb 15, 2006 08:49 AM
fafsa
Apr 6, 2005 03:40 PM
Navid OG
Apr 18, 2004 11:43 AM
bartek_b
Oct 7, 2003 04:45 PM
Takeoff
Aug 11, 2002 01:08 PM
