oil pressure readings at WOT
I'm looking to compare oil pressure readings for a SC'd K20, especially at cold start and at WOT (the high end readings).
8th Civic crowd must not run oil pressure gauges or something, so I had to move from lurker to member here.
sorry to inturrup and my grammar too but my stock b series read high on cold start idk if that helps around 80 psi then goes down when its warm?....
No meter yet at all - one guy said his K20 with JRSC got over 100 psi sometimes, but most oil pressure gauges are only to 100. I can get higher range gauge but somehow doubt I need to, and probably it would be a lot of wasted range and less precise. So just trying to see what others are getting on a similar setup.
mister2racer
Jun 3, 2004 03:46 PM
