h22 crank in a h23 block
Old Jan 5, 2012 | 03:53 PM
lowacc97's Avatar
Icon2 h22 crank in a h23 block
i found a good deal on a h23 and a tranny. i heard somewhere that its a good idea to swap in a h22 crank? if it is a good idea what will work? i can get any info on the block if needed. thanks yall
Old Jan 5, 2012 | 07:58 PM
f22 killer's Avatar
Default Re: h22 crank in a h23 block
Why??? The h23 has a 95mm stroke compaired to the h22 and its 90.7 mm stroke I'd want the 95mm crank myself
Old Jan 5, 2012 | 08:14 PM
GhostAccord's Avatar
Just wondering where you heard that?
Sure it can be done. Is it a good idea, if your asking me for my opinion, I say absolutely not. However, I guess it comes down to what you are looking to get out of it.
Budget? Goals? What is the engines intended use?
Old Jan 5, 2012 | 09:54 PM
f22 killer's Avatar
Are you sure its not a h22 head on a h23 block. That makes more scene and has been done alot.
Old Jan 8, 2012 | 07:59 AM
lowacc97's Avatar
i was told that would work to. the reason they gave me for wanting to do the crank change was that the H23 crank is cast and the H22 crank is forged and could handle more rpm
Old Jan 8, 2012 | 09:31 AM
hondasdohc's Avatar
All honda cranks are forged or at least they should they are the strongest stock they are tough the only thing that messes them up is the bearings when spun. H23 crank is the same crank as f22a1/a4/a6/b1/b2/b and they are forged.
Old Jan 9, 2012 | 02:47 PM
lowacc97's Avatar
ok, this is my first honda so i didnt know. any advice on mods? i do plain on driving it every day
adam94lude
Oct 12, 2005 01:56 PM
hu
Jul 16, 2005 10:44 PM
crj_lll
Jul 8, 2004 03:08 PM
civicsitek GanGsTa
May 20, 2003 04:16 PM
