Vtec won't engage!!!
Old Jan 4, 2012 | 04:28 PM
EKD16Y8's Avatar
Default Vtec won't engage!!!
I have a 96 civic hatch with a d16y8 sohc vtec motor. I bought the car with the motor in it but it had the dx intake manifold, ecu and harness. I recently installed the correct intake manifold, harness and ecu and noticed the vtec did not engage. I then checked the knock sensor and noticed it was broken so I replaced it with a brand new one and plugged it in and still no vtec. I also tried it with my buddy's chipped p28 ecu and still no vtec. I would greatly appreciate anyone's input on this issue before I take it to a performance shop and get raped for probably something simple. Thanks
Old Jan 4, 2012 | 04:34 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Vtec won't engage!!!
I'm guessing you have the DX head as well. Is her a VTEC solenoid on it?
Old Jan 4, 2012 | 04:47 PM
EKD16Y8's Avatar
Yeah..It has a Vtec solenoid
Old Jan 4, 2012 | 04:57 PM
The Grumpiest
Is it wired for VTEC? Can you rev past 5500?
Old Jan 4, 2012 | 05:03 PM
EKD16Y8's Avatar
Yeah it redlines no problem but just no vtec. I even tried a tester on the solenoid and reved it past 5200rmp and nothing.
Old Jan 4, 2012 | 05:04 PM
The Grumpiest
So how do you know VTEC is not engaging? It's not like a Nightrider turbo boost.
Old Jan 4, 2012 | 05:20 PM
flmzero13's Avatar
clean the vtec soleniod
Old Jan 4, 2012 | 05:22 PM
EKD16Y8's Avatar
I know it's not like a nightrider turbo boost...but I've owned several honda's and acura's and when Vtec kicks in you can hear it especially with an intake and I also put a tester on the solenoid and no voltage after 5200 rpm when it's supposed to light up. I also tried a chipped ecu from a gs-r and it lit up but it was misfiring like crazy.
Old Jan 4, 2012 | 05:26 PM
apexi_rsx's Avatar
low on oil????
Old Jan 4, 2012 | 05:29 PM
EKD16Y8's Avatar
nope it's good on oil
Old Jan 4, 2012 | 05:30 PM
EKD16Y8's Avatar
and the solenoid is clean..It's like i've tried everything and nothing works
Old Jan 4, 2012 | 05:35 PM
Dontoh's Avatar
vtec won't engage sitting still, so putting a tester on the solenoid won't work unless someone else was driving while you rode along under the hood..
if vtec isn't engaging, you'll have a CEL, which CEL do you have?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Jan 4, 2012 | 05:43 PM
EKD16Y8's Avatar
Oh ok..My check engine light is on but it's because the sensor that goes to the cat is not in...
Old Jan 4, 2012 | 05:44 PM
Dontoh's Avatar
are you sure thats your only cel?
Old Jan 4, 2012 | 05:47 PM
worx's Avatar
I wouldn't get vtec to work while my cel was on.
Old Jan 4, 2012 | 06:03 PM
Dontoh's Avatar
that too.. handle with care haha
Old Jan 4, 2012 | 06:13 PM
HondaPartsHero's Avatar
Technical Hero
What rpm does it rev to?
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
Old Jan 4, 2012 | 06:18 PM
Ruy's Avatar
Ruy
Check ur vtec selenoid that is engaging right
Old Jan 4, 2012 | 06:21 PM
EKD16Y8's Avatar
it revs to about 7200 rpm.. I'm going to take the car to my local parts shop and use their diagnostics tool to see what cel codes I get and i'll post it tomorrow..
Old Jan 4, 2012 | 06:42 PM
Texas4door's Avatar
Perhaps the ECU is no good?
Old Jan 4, 2012 | 07:56 PM
EKD16Y8's Avatar
I tried a couple of ecu's..I have a p2p, I tried a p28, and a chipped p28..last week the vtec came on with the chipped p28 and after I put the new knock sensor, it never came back on with the chipped ecu
Old Jan 4, 2012 | 08:34 PM
worx's Avatar
most chipped ecus will have the knock sensor deleted. you can get the codes on obd2 cars just like on obd1
Old Jan 7, 2012 | 10:13 AM
EKD16Y8's Avatar
ok I just hooked up the code reader and i got two codes..one for a evap and the other for a o2 sensor..I have the sensor that goes to the cat is not connected because I have a ex harness and theres no plug for the o2 sensor. I don't know what that evap code is about..
Old Jan 8, 2012 | 11:28 AM
EKD16Y8's Avatar
anyone??
Old Jan 8, 2012 | 12:50 PM
apexi_rsx's Avatar
the ex harness has the secondary o2 sensor in the cabin harness. u have to wire it urself with a shielded wire or run a dx harness and wire vtec its easier. this car must have been a dx from factory not an ex.
