rev limiter problem
Old Jan 3, 2012 | 04:57 PM
brad22486's Avatar
Default rev limiter problem
ok have a z6 block w d15z1 head its hitting rev limiter at 4500 rpms cant figure out the problem any help is appreciated thanks
Old Jan 3, 2012 | 05:15 PM
hannslebo's Avatar
Default Re: rev limiter problem
How long have you had the engine set up....was it doing this before? Any CEL?
Old Jan 3, 2012 | 05:20 PM
Dc4LsTeG's Avatar
EK9
What ecu?
Old Jan 3, 2012 | 05:24 PM
brad22486's Avatar
had it for like 4 yrs and its always done it but never cared. but my buddy brought his car over and we swapped his vtec sylonoid dizzy and ecu and still had the same problem. beginning to wonder if the timing is off.
Old Jan 3, 2012 | 06:20 PM
brad22486's Avatar
tried po7 and p28
Old Jan 3, 2012 | 06:23 PM
Dc4LsTeG's Avatar
EK9
So any cels?
Old Jan 3, 2012 | 08:49 PM
ssmtyper's Avatar
**EDIT** cancel what i said... i learned to read. LOL
Old Jan 3, 2012 | 09:18 PM
LoLoCivic's Avatar
its your distributor.. needs a new one
Old Jan 3, 2012 | 10:05 PM
ssmtyper's Avatar
said he already swapped dizzy's
Old Jan 4, 2012 | 04:43 AM
brad22486's Avatar
yea already swapped dizzys and checked timing and iys perfect
Old Jan 4, 2012 | 04:46 AM
grumblemarc's Avatar
The Grumpiest
I'm in to see if one of these rev limit problems ever really gets solved. Apart from plugs getting switched I haven't seen it yet. And it's almost ALWAYS having to do with a swap of some kind.
Old Jan 4, 2012 | 02:41 PM
hannslebo's Avatar
ANY CHECK ENGINE LIGHT???
Old Jan 5, 2012 | 05:58 PM
brad22486's Avatar
yea but i changed everything it was reading and no fix
Old Feb 6, 2021 | 08:08 AM
Jman95@'s Avatar
I took the top end out of a 92 d15z1 eg hatch then I took the bottom end out of a 95 d16z6 out of a ex coupe, everything fit together besides the cam gear, got to use the d16z6 cam gear on the d15z1 head, I can rev it to like 6,500-7k and run just fine, I got the p28 non chipped ecu, it's got 4,000 miles on the build
Guga
Nov 12, 2025 12:04 AM
Hatcheys314
Mar 18, 2010 08:34 AM
slow_srt
Feb 6, 2007 08:08 PM
mar778c
Dec 28, 2004 08:32 PM
StupidSlowRSX
Nov 8, 2004 04:15 AM
