UCA bushing removal.
Old Jan 2, 2012 | 06:00 PM
1994_Integra's Avatar
Default UCA bushing removal.
Read something about using a piece of treaded rod, nut, and washers to remove the UCA bushings on my 94 Integra. I can't find the thread again, was wondering if anyone can help with that? Or do you have any other suggestions on how to remove these bushings? I do not have a press, torch SUCKS! I've been using a hole saw and hack saw for the LCA bushings, slow but effective...Should I just continue with this method?
Old Jan 2, 2012 | 06:10 PM
Hidenplanvew's Avatar
Default Re: UCA bushing removal.
You could use something like the long bolt but you would need something for the bushing to go into so it would have to be larger then the bushing just like a press
Old Jan 2, 2012 | 07:25 PM
GagnarTheUnruly's Avatar
Rent/buy a press or have a shop do it. Otherwise torching is your best option -- but you need something hotter than propane.
wvland
Suspension & Brakes
Jan 5, 2014 02:18 PM
exies
Suspension & Brakes
Feb 9, 2011 06:08 AM
goofke
Suspension & Brakes
Nov 19, 2008 12:49 PM
aserenehope
Dec 7, 2006 02:27 PM
fathergoose
Sep 20, 2003 11:28 AM
