CRX 88-89 vs 90-91 Door protectors
Old Jan 2, 2012 | 11:56 AM
LoveDeezNutz's Avatar
Default CRX 88-89 vs 90-91 Door protectors
Is there a difference in the door molding protectors? I need to replace the door protector the strip in the middle of the door (not the bottom). I dont want to order a full set since only one is missing (88) but dont want to buy just one if one will not be the same thickness.
Is there a difference in the thickness?
Old Jan 2, 2012 | 02:17 PM
Old goat's Avatar
Default Re: CRX 88-89 vs 90-91 Door protectors
yes the 88-89 are thicker and the 90-91 are thinner
Old Jan 2, 2012 | 04:28 PM
I cant get a clear explanation on what part is thicker and thinner. I am HOPING the are the same size just the 88-89 will stick away from the car further and wont look below.
Do you know if they will fit correctly (as in not have a gap)?
../ <---gap
.|#| <----90-91
..\ <---gap, what i dont want
Or will it fit fine:
.|##| <----88-89
I cant find an 88-89 for left side, but for sake consistency I am thinking of buying 90-91 but dont want to waste money on something that wont look right.
Old Jan 2, 2012 | 05:23 PM
mt-fly-boy-25's Avatar
Get the correct year to match all the trim or it looks like ***....
Old Jan 3, 2012 | 10:48 AM
I am just trying to think of alternatives besides having everything shaved, which I dont want to. I can get all 6 protectors for an 90-91 as they still sell them, but I obviously would prefer to get 1 that matches with the current ones, I just dont want a gap since I cant find any clarification what "thickness" refers too.
It not sticking out as far as my current ones I could deal with, but if it means the "height" I dont think I could deal with a gap. Its getting hard to find replacement things, but dont want to drive around with 5 out of the 6 protectors.
Old Jan 3, 2012 | 03:16 PM
Deetz's Avatar
Crazy Honda Guy
The difference is small, but noticable between the two designs. Keep in mind that the bumpers are molded with which ever style too, so you are best to get the proper molding tthat matches them.
It is the width of them that is different, not how thick they stick out from the side of the car
Old Feb 25, 2013 | 07:00 AM
'92 HatchGuy's Avatar
I need to get two moldings as well. R, RR quarter panel and R, FR fender for JDM EF6. I will get some pics uploaded soon. So far I think 87-88 might be what I need, the thinner ones are EF8 Sir.
Old Feb 25, 2013 | 02:35 PM
Deetz's Avatar
Crazy Honda Guy
The thinner moldings started being produced for 1990 and newer models, when the EF got it's refesh along with newer bumpers, tail lights and instrument cluster
Old Feb 26, 2013 | 10:33 AM
Hey Deetz, is that USDM you referring to? I checked your CRX link on H-T and I see you bought the JDM EF8 front bumper. Now I did the same conversion using EF8 front bumper but the rest of moldings are 48mm in width and little more flat than the EF8, kinda like those in the 1st pic of your car. I need to get every molding to match the JDM front end. Do I get North American market CRX 90-91 rear bumper and moldings???
Last edited by '92 HatchGuy; Feb 27, 2013 at 04:41 AM. Reason: I posted wrong measurement, its 48mm
Old Feb 26, 2013 | 03:24 PM
Deetz's Avatar
Crazy Honda Guy
The difference was so small, i actully chose to keep the larger 89 rear 1/4, door, and fender moldings, and use the 90-91 bumpers. Yes, it you want to atch it up 100%, use either a usdm 1990-91 molding, it is the exact style used on jdm SiR (really all 90+ ef front ends), as well as edm VT and 1.6i models
Old May 7, 2013 | 10:40 AM
Well I couldn't find any USDM bumpers 90-91 so I ordered this one from Ebay:
http://www.ebay.com/itm/181059408200...84.m1439.l2649
Old May 8, 2013 | 04:29 AM
zrickety's Avatar
Don't know where you are located but I have both bumpers and all trim for a 90-91 crx. The middle trim differences are small, everything swaps over.
AMseven
Mar 30, 2009 06:06 PM
JDM_EK_JOE
May 11, 2006 10:12 AM
spettinger
Nov 19, 2002 09:44 PM
chhuong
Nov 12, 2002 11:55 AM
