Suspension & Brakes Theory, alignment, spring rates....
Braking issue, help needed.
Old Jan 1, 2012 | 05:43 PM
crazy4hp's Avatar
Default Braking issue, help needed.
Well I have a 94' CX hatch. I did a integra disc upgrade on all four corners. Everything was working fine, then the car was parked for a good 6 months and the braking was horrible after that. The braking would barely slow the car down even when it is slowly rolling. I had changed the master cylinder to a 1" w/ the integra brake booster. I had also changed the brakes and bought a brand new 40/40 prop valve and also just changed the right rear caliper due to the piston being stuck. I'm out of ideas, any suggestion would really be appreciated.
Old Jan 2, 2012 | 07:59 PM
crazy4hp's Avatar
Default Re: Braking issue, help needed.
Wow.. No help? I guess I'll have to go somewhere else.
Old Jan 2, 2012 | 10:45 PM
2fast4urass's Avatar
did try bleeding the brakes by any chance it might just be air and if you keep using the car like that you might mess up the master cylinder, if you have time can you check out my question thanks
Old Jan 3, 2012 | 03:37 AM
crazy4hp's Avatar
Yes, I have already bleed the brakes. I notice the braking has gotten stiffer on the pedal, would that be caused from something being off or something being malfunction?
Old Jan 3, 2012 | 12:43 PM
BuyBrakes.com's Avatar
If your pedal has gotten STIFFER after bleeding your brakes, that is a good thing, it just means you have removed any remaining air in the brake lines. This could be the cause of your bad braking experience, is the car still not braking correctly after you bled the brakes?
FWIW, you will want to bleed in the following order right rear, left rear, right front, left front.
Old Jan 3, 2012 | 08:33 PM
crazy4hp's Avatar
I'll have to try bleeding the brakes in the order you suggested to see if that would help. I have bleed the brakes several times after the installation of all the parts I thought that would be the cause but the car still slides even in a 5 mph roll. I have to really press down on the pedal to get it to grab. Any other suggestions?
Old Jan 4, 2012 | 04:51 AM
What has me stumped is that you said your car worked fine with after the brake conversion and then after 6 months it just all of a sudden stopped working..bleeding in the correct sequence may help, but since you have bled it several times since then, I doubt it will correct your issue.
Let me see what some of our other guys might have to say about it. Do you have good pads and rotors on the car?
Old Jan 4, 2012 | 05:16 AM
crazy4hp's Avatar
Yeah I just recently bought new pads from Advance Autoparts for all four corners. I was thinking about taking the disc to a shop to resurface all of them but the disc don't look bad at all. I notice that when I drove the car around the block I can hear one of the rear disc is a little warped.
Old Jan 4, 2012 | 05:41 AM
94EG8's Avatar
Seagull Management
Did you check to see if the caliper slide pins are seized? Clean and lubricate them with synthetic brake lube. Do not put neverseize on them.
Old Jan 4, 2012 | 05:47 AM
crazy4hp's Avatar
Originally Posted by 94EG8
Did you check to see if the caliper slide pins are seized? Clean and lubricated them with synthetic brake lube. Do not put neverseize on them.
No I haven't check the caliper slide pins. I'll check that today.
Old Jan 4, 2012 | 06:42 AM
+1, would definitely be worth looking into.
Old Jan 8, 2012 | 06:25 PM
crazy4hp's Avatar
Ok, sorry for the late response. I have check the slide pins and bleed the braking system but no change. Could the hardness of the pedal tell me something about the m/c or brake booster? Should the pedal have a softer tension for braking?
eboR
Suspension & Brakes
Oct 1, 2010 02:19 PM
jasonweaver88
Jun 29, 2007 10:31 AM
Filliam H. Muffman
14
Aug 2, 2004 06:24 PM
Terminator Sol
May 17, 2004 08:20 AM
civicSIracer96
Feb 12, 2004 06:31 AM
