94 Civic/B18c1 swap - bad rings or head seals??
Old Jan 1, 2012 | 02:32 PM
felon-k20's Avatar
Default 94 Civic/B18c1 swap - bad rings or head seals??
hey guys need help here .. my car is smoking white i know that can be from head seals or piston rings.but how do you exactly which one it is.. before taking the motor apart ..
the car seems to smoke when i let off the gas pedal.i just bought the car b18c1 anyways the motor pulls hard no lack of power here
Old Jan 1, 2012 | 02:34 PM
grumblemarc's Avatar
The Grumpiest
Default Re: rings or head seals??
Leakdown test.
Old Jan 1, 2012 | 02:36 PM
Wrona's Avatar
white is coolant not oil just saying
Old Jan 1, 2012 | 03:11 PM
Former User's Avatar
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Jan 1, 2012 | 03:18 PM
felon-k20's Avatar
done
Old Jan 1, 2012 | 03:19 PM
Kohen's Avatar
do a leakdown test and compression test.
you may have a blown headgasket, because of the white smoke.
pretty sure bad rings/seals is blue smoke from oil.
edit: just saw your edit. "no loss of power" so probably not a headgasket
Old Jan 1, 2012 | 03:21 PM
Originally Posted by felon-k20
done
Thanks. What car?
Old Jan 1, 2012 | 03:37 PM
The Grumpiest
There was no loss of power when my wife's hatch blew it's headgasket.
Old Jan 1, 2012 | 03:44 PM
Kohen's Avatar
oh well thank you for informing me.
Old Jan 1, 2012 | 03:51 PM
Wrona's Avatar
yeah blown headgasket doesnt always loose power
Check if the Coolant has exhaust gasses in it
http://www.cadillacforums.com/forums...-gas-head.html
or check if the oil is milky
also is your coolant slowly disappearing and there is no signs of leaks?
if you have no milky oil or disappearing coolant u can get the tester like in the DIY i posted from autozone thats how we determined my SVT headgasket
White smoke is burning coolant usually the first sign of a blown headgasket
Old Jan 1, 2012 | 04:04 PM
felon-k20's Avatar
Thanks. What car?
This is 94 eg with gsr .ctr cams and pistons
Also if it was a headgasket wouldnt that mean that the car would over heat?cause my car runs cool
Also oil is not milky
Old Jan 1, 2012 | 04:37 PM
GSaura's Avatar
Default Re: 94 Civic/B18c1 swap - bad rings or head seals??
Smoking under vacuum like you're describing is usually from bad valve seals.
Old Jan 1, 2012 | 05:42 PM
Wrona's Avatar
not always did u put the ctr pistons into the block or did u buy it that way cause if the stock headstuds were reused that could be ur problem
Old Jan 2, 2012 | 06:18 AM
felon-k20's Avatar
Yeah i bought the car that way.and notice it smoking on the way home gee lucky me
Old Jan 2, 2012 | 06:21 AM
felon-k20's Avatar
Anyways i plan to do a leakdown test thanks guys
Old Jan 2, 2012 | 07:44 AM
The Grumpiest
No. There are no set sign of symptoms for headgasket issues. My wife's hatch also did not overheat.
Old Jan 2, 2012 | 07:48 AM
So true. It's one of the more complex diagnoses to make on an engine as it can manifest in many different ways.
Old Jan 2, 2012 | 02:29 PM
Kohen's Avatar
I'm curious how you knew it was a blown headgasket then. Did you just see white smoke and then do a compression and leakdown test? And/or see oil in the coolant?
Metal Head
Feb 19, 2009 08:37 PM
allmotorgsrekk
Jul 31, 2006 05:13 PM
silverboost
Nov 8, 2005 01:01 PM
egturbo
Aug 1, 2004 09:28 PM
F1Spec
Nov 8, 2002 05:57 PM
