Picked up newish corners same year same body but different...
Old Jan 1, 2012 | 12:49 PM
civicminded93's Avatar
Default Picked up newish corners same year same body but different...
Ive got a 91 hatch and I picked up some corners off of another 91 hatch but the set I picked up attach differently. The ones that were on mine didnt need to be screwed in the ones I picked up do. And they attach to the headlight housing differently. Anybody know why?
Old Jan 1, 2012 | 12:56 PM
crx_si-r's Avatar
Default Re: Picked up newish corners same year same body but different...
U bought 88-89 corners.
Old Jan 1, 2012 | 01:05 PM
I got em free is there a way to make em work?
Old Jan 1, 2012 | 01:18 PM
91efbluehatch's Avatar
you would have to drill and trim and all that bs.
just order a set off ebay for a 90-91 hatch and be done with it.
90-91 has to slip mount tabs on the back and a bracket that you attach to inside the headlight bracket.
88-89 have to screws on the outside of the corner lense and 88-89 are a bit more squared at the top
Old Jan 2, 2012 | 05:12 AM
Clayton's Avatar
H-T Administrator
25 Year Member
reading the original post makes me think, like the others that you got 88-91 corners, but I want to clarify. The ones you bought, did they screw in from the outside?
The new ones screw and mount to the headlights, do your headlights have the provisions for that?
Post pics of both if you don't mind.
Old Jan 2, 2012 | 09:25 AM
http://www.ebay.com/itm/88-89-HONDA-...item3a671cc296
^^those are 88-89 and WILL NOT fit on a 90-91.
i'd be willing to bet these are the style you got.
THESE are for a 90-91...you can note the difference
http://www.ebay.com/itm/90-91-Honda-...item2eba5776f9
Old Jan 2, 2012 | 10:57 AM
jerseys_fyn3st's Avatar
remove the corners and on the fenders of the 90-91 are little tiny clips that the 90-91 corners slide into , since you have the 88-89 corners just go to the junk yard find a 88-89 remover there corners and pop the little clips out those are the clips you need to screw your 88-89 corners onto your 90-91 fenders and headlights dnt worry about the 1 screw corners are light and the 2 screws that go into the 88-89 corners hold the corners onto the bumper noway they are falling off. hope this helps, Note: you have to pull the clips off from behind the fenders.
Old Jan 2, 2012 | 11:01 AM
Same goes for if your 90-91 hatch fenders, and you go to the junkyard and only find 88-89 fenders just use your 90-91 clips that hold the corners in vice versa. clips behind the corners are the only difference. and how the corners mount.. Hope this helps and i know everyway works , i did it all. so dnt let any1 tell you diff i have pics.
Old Jan 2, 2012 | 11:10 AM
wait so your telling him to put 88-89 corners on 90-91 fenders???
WRONG. the shape is wrong and the corners will not fit properly into the fenders
Old Jan 2, 2012 | 05:13 PM
Lmao ok. Listen to him. Just switch out clips ull be fine everything else is self explanatory. Use your head. Trim what u have to on the inner part if u have to.
Old Jan 2, 2012 | 05:22 PM
BigbamaBen's Avatar
That will work. My redneck mobile had that done to it
Old Jan 2, 2012 | 08:18 PM
OP- go to ebay...pay $15 and wait 5 business days.
problem solved. dont be ghetto and cheap.
Old Jan 2, 2012 | 08:23 PM
If my girl gets her money tomorrow shes buying me set so hopin she does
Old Jan 4, 2012 | 08:59 PM
ghosthatch's Avatar
just go back to that junkyard and pull the little clips off and replace yours with those if you want to use them
Old Jan 6, 2012 | 10:21 PM
the comanche's Avatar
I would like my name to be Cattinator
Yeah, be rich like this guy.
His rattle canned wheels are "bronze paint polyurethane take from a mercedes benze paint samples"
Old Jan 6, 2012 | 10:59 PM
crx_si-r's Avatar
your wrong. the fenders from 88-91 are the same. the ONLY differences are in the molding. but that can be swapped out to match the correct year of the car. the rest of the fenders remains the same.
now with the corner lights. in order to make 88-89 fit on 90-91 there are a few things you will need to do, in order to do this the correct way.
1. you will need 88-89 headlights brackets.
2. fender clips from any 88-89 civic/crx for the corner lights to clip into.
3. install
Old Jan 9, 2012 | 05:21 PM
pkdog167's Avatar
You are totally right if you want to use crx croner lights on hatch.
mahatma
25
Aug 15, 2006 09:28 AM
I Like Hondas
Jun 2, 2006 02:48 PM
pinecone
May 1, 2006 10:51 AM
Scantron
Mar 14, 2005 02:53 AM
tunedcivic
Mar 22, 2002 01:38 PM
