88-89 or 90-91 light ?
Re: 88-89 or 90-91 light ? (tunedcivic)
The only different is the headlamp housing and if u use 90-91 headlamp, u have to use 90-91 side marker. 88-89 side marker have 2 screws on the side of the fender instead 90-91 have 1 screw into the headlamp housing . There's a little different. So careful !
Re: 88-89 or 90-91 light ? (superslowhatch)
The only difference is a bracket attached to the housing for the corner lamps. The actual headlight housing is the same, you will just need to swap the bracket for the corner lamps. Good luck getting those screws out though, they usually rust in there, so plan on buying a new set from honda, cutting them off, or upgrading to 90-1 corner lamps.
pinecone
05-01-2006 10:51 AM
steronz
09-18-2004 07:48 AM
CrX-To-Tha-Max
10
03-06-2004 06:04 PM
