D16z6 89 HB oil pressure light problem
Old Dec 31, 2011 | 12:35 PM
AlfieRoach's Avatar
Default D16z6 89 HB oil pressure light problem
So issue is when i drive to work every day the oil pressure light flickers and when i let it completely idle it will shine brighter but only at work. If i drive it anywhere else it wont do it and i had a fender bender in that spot where it started to flicker and ever since then its been flickering at that exact location. the engine is on a rebuild only on 4k right now. the oil pressure switch is an autozone but the pump is oem. and it doesnt make noises and it goes away when i rev it or blip the throttle
Old Dec 31, 2011 | 02:00 PM
DumpdEJ6's Avatar
I like the tuna here
Default Re: D16z6 89 HB oil pressure light problem
Ghosts. Or aliens, but probably ghosts.
Old Dec 31, 2011 | 07:17 PM
AlfieRoach's Avatar
dont think so its doing it when i drive north when i drive back down south it dont do it idles low to 750
Old Jan 1, 2012 | 05:01 AM
crvtectim's Avatar
Slap an oil pressure gauge on it so you can monitor what's goin' on with it.
Aaronw93
12
Mar 3, 2014 10:18 PM
jarven093
Apr 27, 2007 03:27 PM
shrirag
Apr 11, 2007 09:55 AM
PatrickGSR94
Dec 19, 2004 07:45 PM
