Aftermarket MAP sensor
Old Dec 31, 2011 | 11:43 AM
motegicivic's Avatar
Default Aftermarket MAP sensor
96 Civic EX
Today I went to replace my MAP sensor with one from Advance, put it on the and car barely ran.
I double checked the part number, and it was clearly new.
Anyone else use an aftermarket MAP and have problems?
I know before I get lectured about aftermarket parts sucking, it was much cheaper, plus it was returnable so I took a chance.
Old Dec 31, 2011 | 12:30 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Aftermarket MAP sensor
Why are you replacing your MAP, I've honestly never seen a Honda MAP go bad
Old Dec 31, 2011 | 12:32 PM
BryanM.'s Avatar
Resident Gearhead
Return it and get a OE Denso from the junkyard.
Old Dec 31, 2011 | 02:14 PM
Former User's Avatar
If the rubber seal for the MAP sensor leaks, it could cause problems. Is a MAP sensor code thrown?
In addition, after installing a new MAP sensor, you should reset the ECU.
Old Dec 31, 2011 | 04:22 PM
Where is the rubber seal? When I took off the old one, just saw a nipple? No rubber seal even off the old one?
Old Dec 31, 2011 | 04:24 PM
94EG8's Avatar
Seagull Management
It's an O-ring, goes around the nipple on the MAP sensor, if it's not on the MAP it's stuck in the recess in the throttlebody, if it's not in either place it's missing.
Old Dec 31, 2011 | 04:29 PM
Hum, I noticed the opening in the throttle body even when I took out the original didn't see it, unless I miss it? Just looked like a metal hole, if I remember right?
Even the replacement one didn't have an o ring?
I just looked there is an o ring......if it is not there could I cause problems? Since mine was original, possible not there from factory?
Old Dec 31, 2011 | 04:34 PM
Technical Hero
Yeah it would cause your car to run bad or even stall. Doubt it came like that from the factory as it wouldn't run great at all but still probably wouldn't throw a MAP code.
Old Dec 31, 2011 | 04:36 PM
I will have to check again, would it set off a MAP CEL too?
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
baulum
Apr 13, 2008 10:18 PM
reddysol
Sep 8, 2007 10:57 AM
4dooritr
Feb 24, 2006 02:59 PM
