Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
map light acting strange
Old Dec 30, 2011 | 01:24 PM
builthatch's Avatar
MiG-21 superfan
Default map light acting strange
'07 Si sedan.
both (L and R) front map lights work when manually depressed.
when doors are open, the passenger side of the two won't light when the illumination switch is on "DOOR". it also won't light when the doors are unlocked with the keyless entry remote.
it was working intermittently today and then stopped, only working when manually pressing the light.
the passenger side door switch is ok because when that door is opened, the LEFT map light illuminates.
any idea what it could be?
Old Jan 1, 2012 | 05:04 AM
lazlong's Avatar
Default Re: map light acting strange
Check for a bad connection or wire. Then, with the ignition OFF, get out your wire diagram and check continuity (ohms) on the wire(s) for that circuit.
Old Jan 1, 2012 | 07:58 AM
builthatch's Avatar
MiG-21 superfan
it's at the map light box in the roofliner which has built-in circuit traces. everything checks out up to that so one of the traces must have burned up somehow. $20 part so i'm not that bummed but i never knew they would make the plastic map light box so complex!
Old Jan 1, 2012 | 08:15 AM
lazlong's Avatar
And they get more complex every year. Thankfully it was a cheap fix.
sschauhan3
Apr 3, 2018 04:47 PM
woj
Feb 13, 2018 06:17 AM
XIV
Aug 7, 2014 06:51 PM
4DRmafia
May 12, 2011 01:29 AM
MrLeWayne
Audio / Security / Video
Nov 21, 2010 12:46 PM
