EG8 B16A2 Won't Start
Old Dec 29, 2011 | 06:30 PM
OkayTrash's Avatar
Icon3 EG8 B16A2 Won't Start
Hey, new here but im in dire need of help...
I drive a 1993 honda civic with a b16a2 obd1 all motor etc.
I was driving and suddenly i lost all power. Try'd to start it back up, it wouldn't turn over.
Just replaced Cap and rotor and ignition coil ... Problem is still there? any ideas?!
Old Dec 29, 2011 | 09:18 PM
Wrona's Avatar
Default Re: EG8 B16A2 Won't Start
have u checked your main relay do you hear the fuel pump click
are you getting spark or fuel
Old Dec 29, 2011 | 09:52 PM
OkayTrash's Avatar
I have a kill switch for my fuel pump, and that got messed up about... 4 months ago but that got fixed...
i'm pretty sure it could be the main relay...
Old Dec 29, 2011 | 09:56 PM
OkayTrash's Avatar
How can i test if im getting a spark?
Old Dec 29, 2011 | 11:48 PM
dirkam's Avatar
The same happened with me yesterday.
I am curious also how I can check whether there is fuel and spark.
The main relay usually cause the problem that the engine will not start when the car and the cabin is warm, right? At least this was the case for me and re soldering it solved the problem.
Old Dec 30, 2011 | 01:25 AM
HondaPartsHero's Avatar
Technical Hero
Generally the main relay is not the culprit for a stall while driving, here's some links for testing:
Spark
http://www.team-integra.net/forum/bl...eshooting.html
http://techauto.awardspace.com/ignition.html
Main Relay
http://techauto.awardspace.com/mainrelay.html
Old Dec 30, 2011 | 06:21 AM
hannslebo's Avatar
[QUOTE=HondaPartsHero;46595777]Generally the main relay is not the culprit for a stall while driving
x2
Old Dec 30, 2011 | 09:11 AM
OkayTrash's Avatar
Well, my cap and rotor both failed on me. But i know there must be another problem. I smacked around my main relay and it ALMOST started, i hear the fuel pump working also so my ks isn't affecting it. .
krazybeats
Oct 31, 2010 07:34 AM
hex_04
Feb 6, 2008 04:15 PM
livelife46290
Aug 26, 2004 07:07 PM
therealciviczc
Sep 25, 2003 03:07 PM
