Fuel Filter - bottom bolt won't unthread all the way..
So,
I'm trying to change my fuel filter on my 1997 Civic and I've come across a weird problem.
I got the top bolt off fine. I got the bottom bolt loosened (finally)...but it won't unthread completely from the filter. It looks like it's hanging on by 2-3 threads. I try to loosen the bolt, it gets real hard to move, then it gets easy and doesn't move any threads. I can tighten it fine (but not all the way).
I'm assuming the fuel line is crossthreaded into the filter. I'm thinking about taking a dremel to the filter and trying to break the bottom piece off.
Advice? Suggestions?
Be careful since the dremel could cause sparks. Can you grab the head of the screw with pliers hold the filter and pull and turn the screw to get it off?
I've tried holding the bolt with a wrench while unscrewing and pulling the filter, but it just keeps spinning and doesn't actually unthread completely. Either a thread is crossed/broken on the bolt or inside the filter.
Like the top of the filter there is a part on the bottom that you can get a wrench onto for leverage while removing the line. Look at the new filter if you don't know what I'm talking about. I doubt it's crossed threaded.
Yes, I've tried yanking it and using multiple wrenches for leverage. I even took the filter off the bracket, put wrench on bottom fuel line to keep it from turning, and tried to manually loosen the filter by turning it. It won't go past 5-6 threads.
Honestly, if this were me, I would more likely just get mad enough to chop the ****ing line off and run a new one.
Maybe I was thinking of the top line, been long time since I looked at the fuel diagram.
You can try a little Teflon tape on the threads screw back up into the filter and then screw down, the tape might thicken the threads a bit and give you leverage to get the screw out.
forget about replacing the line, and dont ever use a dremel to cut the fuel line.
first you need one of these
pipe cutter..can be found at auto store
go to junkyard and find same nut slide it on the tube then flare it with this tool
Archxor
Nov 7, 2006 04:36 PM
SexyAzNMami
Nov 19, 2004 12:00 PM
