Built K20a2, 6 speed trans, TURBO EVERYTHING $4500 CHEAP Built K-SWAP!!!
Old Dec 29, 2011 | 12:05 PM
dacowgod's Avatar
Default Built K20a2, 6 speed trans, TURBO EVERYTHING $4500 CHEAP Built K-SWAP!!!
VIDEOS:
http://www.youtube.com/watch?v=I_7frnVGYjM
http://www.youtube.com/watch?v=UxBs3ZzmXd4
Please do not waste my time... with lowballs or deadbeat offers... this car has twice in it than i'm asking for..
EVERYTHING... buy the entire car $4500 ... Built Engine, 6 speed trans, wiring, etc!! ... I sold the ECU, BOV, aftermarket wideband, and fuel pump... EVERYTHING ELSE IS STILL HERE AND GOES for $4500!!!! I have a truck and a car trailer...I will deliver within a reasonable distance for some extra $$$ ..
Contact Info:
Ricky Nichols
Morgantown WV
Call or TXT 304-813-2405
The chassis has its fair share of dings dents scratches scrapes key marks etc ... Not really rusting but definitely needs attention.
THE GOOD
Fully Built Engine:
K20a2 - Head and block were machined flat, block was bored .020 over, everything was mic'd and polished, 3-angle valve job etc
Eagle Rods,
Wiseco 9.0:1 Pistons .020 over
ARP head studs
Cometic Head gasket
All new OEM Honda timing components (i.e. OEM Timing Chain, OEM Oil Pump Chain, Chain Guides, Chain Tensioner, etc)
New water pump
Oil pan has been drilled and a 10-an fitting is welded on for a turbo return line...if you are running this NA you can put a -10an cap on it
has roughly 10,000 miles on it... Have videos of it running, free rev and a pull through the first few gears... Will include intake manifold, throttle body Alternator ETC with the long block $2300
6 speed manual transmission from 02 RSX-S roughly 80,000 miles on it shifts excellent, no grinds. $800
Omni 3-bar Map sensor for Acura RSX-S throttle body - $75
850 CC low impedence pte injectors w/ resistor box and injector plugs - $200
Fuel feed from tank to rail w/ fittings -6an and Purple Fuel Lab fuel filter - $150
Aftermarket fuel rail - $40
Purple Fuel lab Fuel pressure regulator with -6an FPR to rail kit, and a custom made fitting to use the stock feed line as a return line (Converted to a returnless system for better control of fuel in boost) - $150
ACT MAXX Clutch roughly 10K miles on it w/ stock flywheel - $250
FMIC Kit w/ all the piping - $125
PTE 5031e 50-trim turbo, Treadstone top mount exhaust manifold, Tial 38mm Wastegate, oil Feed and return lines, and SS Mandrel bent downpipe $1000(I can have the parts to upgrade this turbo to a 6031e 60-trim turbo and can do this for an extra $150 bucks)
Brand new (10,000 miles) OEM Honda Front Wideband o2 sensor - $100
2.5" exhaust from downpipe back (not sure of brand was on car when I purchased it, I punched the catalytic converter though so its hollow but looks to be intact) - $200
Aftermarket Black housing DEVO Headlights ~3000 miles on them - $100
Carbon Fiber hood - $200 (it looks rough clear coat has peeled off of it pretty badly
Rolling chassis w/ clear title $1000 obo ..Theres alot good w/ it and alot not so nice ...but has good suspension, steering, interior is good for the most parts (driver seat is torn up pretty bad) Will leave the wiring harnesses etc intact in the car unless somebody needs them for a swap. This price will vary depending on how much I leave on the chassis.
BUY ME!!!
Old Dec 29, 2011 | 12:13 PM
dacowgod's Avatar
Default Re: Built K20a2, 6 speed trans, TURBO EVERYTHING $4500 CHEAP Built K-SWAP!!!
A couple photos...also have some videos of the car running/driving/boosting/revving just before I sold the ECU ..I will post them on ecu and post links later ...Lets get this out of here..I have other projects to work on..
Old Dec 29, 2011 | 01:44 PM
Smokinsax's Avatar
The Boot
what kind of chassis is it?
Old Dec 29, 2011 | 03:22 PM
dacowgod's Avatar
Its an 02 rsx-s ... Its a k-swap donor car
Old Dec 29, 2011 | 03:48 PM
Fibercation's Avatar
....kinda unclear on what all you are selling?
Old Dec 29, 2011 | 07:50 PM
dacowgod's Avatar
The car with the motor trans and everything else listed in the for sale ad for $4500 or whatever you want from the fs ad itself i jist wanna cut my losses and move on ... I have the clear title too
Old Jan 1, 2012 | 09:23 AM
dacowgod's Avatar
Heres a link to the video of it running
Old Feb 1, 2012 | 04:27 AM
dacowgod's Avatar
Back for sale...
This was Sold...Accepted a non-refundable deposit and everything...then the kid decides to stop answering the phone..and I was notified by paypal that the Deposit was being disputed... WTF ..Please DONT waste my time... This is an insane deal for anybody looking to turbo/build their RSX. I've sent PM's to all of the others that were interested that I told it was sold.. Sorry... DEADBEAT BUYERS FTL
Old Feb 23, 2012 | 06:32 AM
dacowgod's Avatar
Tax time is here guys... Snag this!.. For the price of the Built Long Block you get the entire car, fuel system, Turbo setup and Inter cooler clutch low miles trans and a ton of other goodies!!
As mentioned I have a trailer. I can deliver.. Would be interested in trades for things of equal value.. Would not mind having a nice dependable lower mileage DD to run around in.. or even something like a Polaris RZR side by side would spark my attention .... Also in th emarket for a Diesel truck (Can toss cash on top of this obviously) ..
andyman97
Oct 27, 2015 10:22 AM
Dabrybry
Nov 7, 2008 10:12 PM
hondacura22
May 22, 2008 01:20 PM
Running925
Feb 17, 2007 07:03 AM
h23atsi
Oct 11, 2005 08:55 AM
