Starting hard
Old Dec 28, 2011 | 09:20 PM
Soviet67's Avatar
Icon2 Starting hard
I have a 99 ek with a 00 B18b1 in it. the issue i'm having is that it starts hard. it will crank for like 5-7 sec before it actually cranks over. once its is running for a couple minutes it starts up right away, if i were to shut it off, and turn it back on. its not really a problem just more of an annoyance but i'd like it it to start like it did before i did the swap. anyone know what to check or what the issue might be or have this happen to them?
Old Dec 29, 2011 | 01:17 AM
hunan beef's Avatar
Default Re: Starting hard
Sure the battery is good on charge?
Old Dec 29, 2011 | 07:30 AM
motegicivic's Avatar
I have had the same issue with my y8 for years, esp when cold like 40 degrees and below, I know it is a different engine but maybe common with honda's?
Fresh battery, plugs, wires etc, still does it.
I know with 99-00 ex's has a cold start valve I wonder if they added it because of the hard cold starts.
Old Dec 29, 2011 | 06:28 PM
Soviet67's Avatar
Yeah battery is brand new. It acts like my old engine when my gas tank was on empty. If i Start it and then go to drive with out it being warmed up it starts off slow/sputters until about 1500RPM as if its not getting enough fuel or something but if i let it warm up for like 2-3 min before driving it, doesn't act funny at all. there is no gas leak or vacuum leaks i can find.
Old Dec 29, 2011 | 08:40 PM
chrisaddition's Avatar
Once you turn the key wait until you hear the fuel pump stop running and then try cranking it over, not a permanent fix but may help get rid of the annoyance untill you find the problem
Old Jan 1, 2012 | 07:16 PM
Soviet67's Avatar
Yeah I do that already, which does make the crank time a little less.
Old Jan 1, 2012 | 07:20 PM
vartok's Avatar
whens the last time you changed the fuel filter?
Old Jan 1, 2012 | 07:33 PM
9threEJ's Avatar
Check your fuel system, I have the same problem and let the pump run for a second or two before I crank and it starts right up.
rc.square24
Mar 18, 2013 11:54 PM
KerryTheBeast
May 25, 2010 12:25 PM
vlc92189
Jan 30, 2007 04:53 AM
Silvteg95
Nov 21, 2005 10:45 AM
Sticky Tires
Feb 12, 2003 01:18 AM
