Ls vtec starts but dies after a minute help please!!!
Old Dec 27, 2011 | 09:17 PM
nkmndz's Avatar
Default Ls vtec starts but dies after a minute help please!!!
Ok so I started to notice that my ls vtec was smoking a lot from the breather, so much I had to pull over, the car was running good but smoked a lot. I found out that it was my gaskets when I changed out valve covers I forgot to switch the gaskets over to the new valve cover. My bad!! The oil was dumping into the plugs
Well sucked out all the oil out of the spark plugs and clean everything off. Then purchased new spark plugs. But now when it starts it's idles for about 10 seconds then turns off, but if I press the gas it's good but as soon as I let go it dies. I haven't changed out the spark plug wires yet was gonna try that tomorrow. Is there anything else it could be?
Help please!!!!
nkmndz's Avatar
Default Re: Ls vtec starts but dies after a minute help please!!!
Oh I checked compression all cylinders at 195!
Old Dec 27, 2011 | 09:56 PM
Texas4door's Avatar
Any Check Engine light?
Might be your IACV or your Fast Idle Thermo valve (depends on how old the car is)
If the valve is stuck closed, your car can't get a steady pull of air to keep the motor running, so then it dies.
You adding throttle to keep it running serves as the substitute for that valve.
Old Dec 28, 2011 | 01:21 AM
HondaPartsHero's Avatar
Technical Hero
Either its losing spark or fuel. Did you clean out your spark plug wires?
Old Dec 28, 2011 | 01:56 AM
apexi_rsx's Avatar
is this car chipped? are you running the fast idle valve? if u held ur foot on for a few mins for it to warm up some will it stay idling? i know mine car is chipped and im not running a fitv and my idle stays at 1000 all the time when its cold out it doesn't wanna stay running unless i hold my foot on the gas and let it warm up alil.
Old Dec 28, 2011 | 02:26 PM
nkmndz's Avatar
no check engine lights. its a 92 civic si
car is chipped on chrome, not sure if its runing fast idle valve. I havent cleaned out the spark plug wires i'm going to once i get home or just put a friends on for testing.
Again the car was running fine until i found the problem with the oil on the spark plugs. I'm thinking that when i pulled the wires out is when them might have gotten oil on the inner part of the wires.
Old Dec 28, 2011 | 02:31 PM
sfar785's Avatar
turn up your idle for a little bit and try that to see if it helps anything
Old Dec 28, 2011 | 05:32 PM
nkmndz's Avatar
Changed out the spark wires and lkept my foot on the gas for high idle still turns off any help!!!!
Old Dec 30, 2011 | 06:33 AM
nkmndz's Avatar
Help
Old Dec 30, 2011 | 06:57 AM
nealnanoHX's Avatar
Help please!!!!
Did you replace the wires as well?? The oil in the plugs will cause the spark to ground instead of going to the park plug. Try replacing the wires. Oil in the spark plug holes can cause a bad misfire or even stop the spark from reaching the plugs.
Old Dec 30, 2011 | 08:10 PM
nkmndz's Avatar
I replaced wires and plugs still runs like ****
Old Dec 31, 2011 | 08:42 AM
Former User's Avatar
Old Jan 1, 2012 | 04:34 PM
nkmndz's Avatar
Still troubleshooting
Old Jan 1, 2012 | 04:36 PM
Summarize what you've done so far.
Old Jan 1, 2012 | 06:28 PM
nkmndz's Avatar
Changed out te plugs wires and checked the firing order
Old Jan 1, 2012 | 06:40 PM
Did you run the engine until it was warmed up?
Old Jan 1, 2012 | 08:46 PM
nkmndz's Avatar
Yes 30 min. A friend of mine said it might still be the oil that was in the spark plugs walls that dropped into the cylinders and might need time to burn off. I took out most of the oil that was in there before pulling and the spark plugs in the beginning.
Old Jan 5, 2012 | 07:43 PM
nkmndz's Avatar
Bump
LowNSlow6
May 16, 2013 08:00 PM
gratua
46
Mar 5, 2012 07:55 AM
nkmndz
Feb 25, 2012 05:12 AM
lke2drvgsr
Sep 29, 2003 07:25 PM
garagespecial
Jan 16, 2002 07:51 AM
