z6 smokes really bad upon start up
i have a d16z6 that smokes really bad when i start it up. i just got done replacing the valve seals on it. I replaced the new hg and did a compression test and they came out good.
here is a video on it. any help is appreciated it.
http://www.youtube.com/watch?v=a04DI...e9AUAAAAAAAAAA
did a leakdown all was under 20%
compression seem to be a little low
heres another video
http://www.youtube.com/watch?v=o7mPF...67AUAAAAAAAAAA
heres another video
Jeebus
Either it's REALLY frickin cold there, or you're burning coolant dude
What does the smoke smell like?
Kinda sweet, or like burning oil?
If it's the former, you may have further head gasket issues/warped head or block and therefore burning coolant
If it's the latter, especially with your lower compression, you may have badly worn rings and therefore burning oil
What were the compression numbers? Although, I doubt that is it, seeing as the smoke is white.
When you did the HG, did you check the block/head to see if it was warpped?
head wasnt warp it was flat i did a leak down and all cycl were under 20%
that day i recorded the vid it was only 50 degrees out not too cold.
I filled up the oil all the way full and and started for 15 mins and the oil level went down to half on the dip stick Im thinking its really wore rings the motor has 215xxx miles on it
i dont remember the comp numbers sorry
whats it smell like? cuz it looks like coolant? if you just replaced the headgasket did you put it on the right direction? I have done this before myself and fired the motor and I had water and coolant leaking out places it shouldnt. I pulled the head off and realized i should have just went to bed ensted of trying to rush through the build hahaha have you boosed this motor before?
yes it put it on the right direction it smoked before i did the hg also and it smells like burnt oil
the coolant level is fine. it has oil residue all in the exhaust of the car.
the motor has never been boosted.
I had a car did the same thing. My problem was the rings. Yours is either the rings or the valve seals. When you replace the seals did you do one at a time or remove all at once?
I am burning oil as well, but not that bad.
they were supertech valve seals btw.
yes was smoking this bad before the valves were done.
i'm jst gonna go ahead and pull the motor.
i started it with the headers off and it was just blowing oil out of all the cycl.
thanks for the response.
very much appreciate it!
vipokc
Feb 4, 2009 06:57 AM
menappi
Aug 14, 2005 06:42 PM
