Weird Engine Noise
1991 Honda Accord 5-Speed Manual. The car has noisy valves like all of these cars now, but when I hold the rpms steady around 2000 it starts to make make a weird sound. It kind of sounds like a scratchy knocking sound, and while it does this the engine seems to miss. While its doing this you can feel the engine shake. What could it be?
I was thinking maybe spark knock.
It does it all the time and it is bad around 1200 rpms but once it gets above that it is just ticking. How would I clean the EGR and what would this problem in the rpm range mean to you? The car still has all of its power.
Ok here is the best way I can put the sound. Under load like taking off or driving slow in a high gear it will start to sound like a diesel. So if that helps diagnose it thanks.
I also have clutch chatter is there anyway it could be flywheel?
CodeBlue
Honda Civic (2006 - 2015)
11
Feb 3, 2010 09:25 PM
