Suspension & Brakes Theory, alignment, spring rates....
koni yellow bolt size
Old Dec 26, 2011 | 11:01 AM
aMp-_-'s Avatar
Default koni yellow bolt size
The bottom bolt on my koni yellows fell out and I need to know what size it is, so I can go to lowest and buy one. I got 12x1.5 searching the internet , but still haven't found anything. I would call koni, but they're closed. Anyone know? Thanks. I have an rsx BTW
Old Dec 26, 2011 | 12:01 PM
racebum's Avatar
Default Re: koni yellow bolt size
one way you can getting it going right now is it to drill out the nut and use a grade 8 nut/bolt combo. i'm fairly sure it's 3/8" and just measure for the correct length. or, just go to lowes with the bolt you already have and buy one the same size. the metric bolts MUST be rated 12.9 if you can find them and by finding it usually means ordering from a specialty nut/bolt company.
option B is just going to acura and buying the correct honda part which honestly would be easier if you want to use the koni nut
Old Dec 26, 2011 | 03:19 PM
aMp-_-'s Avatar
This is what im talking about. Non Honda Part
Old Dec 26, 2011 | 03:34 PM
racebum's Avatar
no clue what shock that car fits, in a situation like that use a thread tester to determine pitch then order the correct bolt either via koni or a bolt store. most bolt stores have testers you can use to determine pitch. take the shock with you and google your local nut n bolt stores
Old Dec 26, 2011 | 05:14 PM
aMp-_-'s Avatar
thanks for the help... I guess ill just call koni tomorrow. It was frustrating trying different bolts and not buying the right one lol
Old Dec 26, 2011 | 07:34 PM
racebum's Avatar
can be, and it's not just the right bolt, it has to be the correct strength as well. generally if you replace any oem bolt with one from a store it should be grade 8 or metric 12.9. even if koni told you what the bolt was it would enable you to call around and ask for the correct bolt
Old Dec 26, 2011 | 10:21 PM
aMp-_-'s Avatar
I'll call koni tomorrow and post the size, so I can help somebody out atleast.
Old Dec 27, 2011 | 07:19 AM
aMp-_-'s Avatar
Koni is actually closed until January the 2nd lol Wtf!
Old Dec 30, 2011 | 06:07 AM
aMp-_-'s Avatar
It was for an RSX Type S. I finally found the bolt at Oreillys! size m12 x 1.5 If anyone in the future has this same problem
alpinegroove
Nov 18, 2013 01:27 PM
dan89crxsi
24
May 18, 2008 10:25 AM
hmtcrxsir
Nov 7, 2005 01:02 AM
Caveman74
Mar 29, 2004 12:50 PM
B16Ej1
Mar 26, 2003 11:21 AM
