car idle, jumping, and clock dimming
Old Dec 26, 2011 | 02:05 AM
mish__'s Avatar
Default car idle, jumping, and clock dimming
today i changed the oil and filter on the car.
i drove it a couple blocks and it came back home, it was fine...
then, drove it out tonight... a couple hours after before and the car was running
rough, like it didn't want to go, then it was idling weird sometimes when the car was stopped and i noticed the clock would get dim on and off even if the car wasn't idling weird.
i know one battery terminal is corroded, would it cause that?
or would it be a fuse problem? thanks.
Old Dec 26, 2011 | 04:17 AM
grumblemarc's Avatar
The Grumpiest
Default Re: car idle, jumping, and clock dimming
Don't sit there wondering about it. Clean the terminals. Then have you battery and alternator checked.
Old Dec 26, 2011 | 06:14 AM
sfar785's Avatar
if your terminal is corroded then you have a bad connection, which will cause your Honda to run like **** and not even start at times.
Old Dec 26, 2011 | 11:27 AM
Hidenplanvew's Avatar
easy test... get a DVOM put the black wire to - and red to + and start the car... If your below 14.xx then your alt is prob on its way out. You can also check if the grounds are dirty by Making a test lead... hook it to your - battery cable and while the car is running touch diffrent areas around grounding points if the volage rises then you have a bad ground or more then one. Make sure to use 12awg wire as it can flow more current..
slammed98sedan
Dec 25, 2014 07:12 AM
antig24
Jun 27, 2009 10:27 AM
Sparks23
Jul 31, 2007 04:47 PM
Timmay
Feb 27, 2004 04:01 PM
bluesaint
Mar 6, 2003 09:38 AM
