94' LS Cranks but no start
Old Dec 24, 2011 | 09:25 AM
redcivic's Avatar
Default 94' LS Cranks but no start
Hey guys, long time no see. I have been out of the Honda scene for years and currently have a turbocharged RX-8. Anyway, I picked a 94' LS as a daily. Bone stock, well maintained. I was driving along and it died. From past experiences in my Civic and CRX I figured it was the ICM. I went ahead and replaced the cap, rotor, coil, and plugs so I could start fresh. Well, it still does not start. The pump primes and I have fuel at the rail. It cranks but nothing. I tested everything as per the advanced ignition troubleshooting page on TI and everything checks out.
Bad distributor? I don't remember them just dying like that but what do you guys think? Thanks!
Old Dec 24, 2011 | 09:31 AM
DirtyDA9's Avatar
Default Re: 94' LS Cranks but no start
You did all that with the distributor and didn't even replace the ignitor which is most likely your problem. Or the ignition switch maybe. Also even if you have pressure at the rail doesn't mean the injectors are working, so test those. Do a compression test. Check codes. Do you test to see if it has spark at the plugs or not?
Old Dec 24, 2011 | 10:01 AM
redcivic's Avatar
Where is the ignitor? All the wires seem ok at the switch, I jiggled wires and the key to see if it would do anything and it still cranks but doesn't turn over. I realize pressure at the rail doesn't mean the injectors are working but I have never heard of injectors just failing like that.
I am going to check the plugs now.
Old Dec 24, 2011 | 10:05 AM
redcivic's Avatar
Is this the ignitor or ICM? I replaced this but they called it the ICM and so does the thread on Team Integra.
http://z.about.com/d/autorepair/1/0/I/8/42172714.gif
Old Dec 24, 2011 | 01:41 PM
geek504's Avatar
ICM is the igniter.
Did you get it running yet?
how was the spark plugs?
Old Dec 24, 2011 | 02:51 PM
DirtyDA9's Avatar
yea that's it.
Old Dec 26, 2011 | 06:36 PM
redcivic's Avatar
No I haven't gotten it started. The old plugs were brown but not horrible. I am going to check the wires and plugs for spark tomorrow. It just cranks, nothing else. All fuses and relays are good.
Old Dec 26, 2011 | 07:40 PM
Kushaholic420's Avatar
so are you getting spark??? did you pull out each spark plug and ground them??
Have to checked if you have enough battery power, sometimes this is the problem.
markopolo
Mar 1, 2017 05:52 PM
Kneedraghonda
Apr 7, 2010 03:54 PM
ANNiHiLATORS
Sep 6, 2009 04:05 PM
Meesterzoomak
Jan 25, 2007 04:25 AM
91amatuer
Jun 11, 2006 10:52 AM
