vacume line idle trouble
Old Dec 23, 2011 | 12:49 PM
jayscivi's Avatar
Icon6 vacume line idle trouble
where can i find the vacume line on a 96 cx hatch im pretty sure mine has craked and is causing the car to idle rough please help if you have a picture please post
Old Dec 23, 2011 | 12:53 PM
mmcd's Avatar
Default Re: vacume line idle trouble
have you checked the IAC?
Old Dec 23, 2011 | 01:02 PM
jayscivi's Avatar
yes and its fine
Old Dec 23, 2011 | 01:08 PM
delsolo95's Avatar
buy some carb cleaner and start spaying the lines while car is running. once sprayed at a particular line the rpm will drop and boom! replace that line
Old Dec 23, 2011 | 01:19 PM
jayscivi's Avatar
will penatrating oil work ?
Old Dec 23, 2011 | 01:20 PM
delsolo95's Avatar
carb or brake cleaner cause it has some type of alcohol iirc and is highly flammable
Old Dec 23, 2011 | 01:21 PM
jayscivi's Avatar
ok thanks ill go try it out
delsolo95's Avatar
if idle doesnt surge when spaying all of the lines then check the iacv
Old Dec 23, 2011 | 01:23 PM
jayscivi's Avatar
i have taken the iacv off and cleaned and it did not change anything
Old Dec 23, 2011 | 02:45 PM
apexi_rsx's Avatar
seafoam the motor if its got high miles on it help break that carbon build up.
Old Dec 23, 2011 | 05:22 PM
delsolo95's Avatar
what did you clean it with? and did you try spraying carb cleaner on all vacuum hoses?
Old Dec 26, 2011 | 12:27 PM
sandman67's Avatar
Wats up ? Just wanted to say I've heard of people putting a cup of sea foam and letting the vacum line take it in and remove all that junk out and thier car ran better .I myself havn't tried it yet. Though, I've tried seafoam in my crankcase and fuel tank and swear by it. Sandman67
Old Dec 30, 2011 | 03:55 PM
jayscivi's Avatar
The lines were fine it was a map sensor
Old Dec 30, 2011 | 04:27 PM
motegicivic's Avatar
How did you find out it was map?
SiRCiviC94
May 13, 2012 10:05 AM
quickv8s10
Aug 7, 2007 03:30 PM
egmadness
Jun 7, 2006 09:34 AM
adamjenkins80
Apr 15, 2005 09:04 AM
Spec R
Apr 8, 2004 10:26 AM
