Cylinder 4 not reaching tdc. Crank will not rotate by hand????
Old Dec 23, 2011 | 03:53 AM
robertjegan's Avatar
Default Cylinder 4 not reaching tdc. Crank will not rotate by hand????
I blew a headgasket. Car ran for possibly four to five minutes. Milky oil all in the pan. Fix it all turn it back on and the car knocks horribly and all the lights come on the dash.
Cut it off instantly.
Pull plugs and try and rotate by hand but stops at a certain point and cannot make a full rotation.
Took the head off.
Cylinder 4 is not making it all the way to tdc and its off id say a quarter to half inch from cylinder 1
the point it seizes up is when all the pistons are in the middle of the block.
What could this be? Is it blown?
Old Dec 23, 2011 | 04:20 AM
94EG8's Avatar
Seagull Management
Default Re: Cylinder 4 not reaching tdc. Crank will not rotate by hand????
Bent rod. Replace the engine.
Old Dec 23, 2011 | 04:31 AM
Figured that was the case.
CptHMCrunch
Honda Civic (2001 - 2005)
Jun 30, 2013 11:49 AM
h2.4
19
Feb 19, 2010 09:39 AM
redline870
Sep 15, 2009 10:51 AM
hmtcrxsir
Jun 19, 2009 09:21 PM
JFG Kevin
Aug 28, 2006 09:47 PM
