alignment question
Old Dec 22, 2011 | 04:35 PM
swizz977's Avatar
Default alignment question
can they adjust caster and toe in the rear or only the front
Old Dec 22, 2011 | 04:40 PM
TunerN00b's Avatar
Default Re: alignment question
Neither.
There is no such thing as caster in the rear.
Aside from that, caster isn't adjustable in the front either.
Old Dec 22, 2011 | 04:43 PM
swizz977's Avatar
are u sure ?? wat about toe??
Old Dec 22, 2011 | 04:57 PM
apexi_rsx's Avatar
yes they can adjust toe on the rear u have adjustments on the rear trailing arms.
Old Dec 22, 2011 | 05:11 PM
swizz977's Avatar
ok can they asjust the toe in the front too??
Old Dec 22, 2011 | 05:15 PM
TunerN00b's Avatar
Well, that answers that.
Definitely not trolling.
Old Dec 22, 2011 | 05:46 PM
Markley02's Avatar
Using stock components they can adjust the toe and camber in the front. Just toe in the rear. You can get creative with washers to get more positive camber in the rear.
Old Dec 22, 2011 | 06:24 PM
TunerN00b's Avatar
Wrong.
Only toe is adjustable. Every single Civic has been this way for the past 30 years.
Old Dec 23, 2011 | 03:47 AM
94EG8's Avatar
Seagull Management
Originally Posted by TunerN00b
Wrong.
Exactly. I used to do alignments when I worked for Honda. The only thing you can adjust is the toe, if you need to adjust camber you need adjustable upper control arms.
Edit, forgot like half a sentence, makes sense now.
Old Dec 23, 2011 | 09:00 PM
NotAJDMFanBoy's Avatar
You can get adjustable coilovers and when you adjust the ride height, it will affect camber. This is more if you're trying to gain negative camber, not adjust it like for an alignment.
Old Dec 23, 2011 | 09:07 PM
ifIexplode's Avatar
This **** is just Lulz
houa-kage
Honda Civic (2006 - 2015)
Oct 29, 2010 11:21 AM
huge230
Apr 8, 2006 05:22 PM
2000turbosi
Suspension & Brakes
Mar 26, 2006 08:24 AM
revolt_allmotor
Suspension & Brakes
Nov 6, 2005 09:04 PM
01CWITR
Aug 6, 2002 05:32 PM
