alignment question
Old 12-22-2011, 04:35 PM
swizz977's Avatar
Default alignment question
can they adjust caster and toe in the rear or only the front
Old 12-22-2011, 04:40 PM
TunerN00b's Avatar
Default Re: alignment question
Neither.
There is no such thing as caster in the rear.
Aside from that, caster isn't adjustable in the front either.
Old 12-22-2011, 04:43 PM
swizz977's Avatar
are u sure ?? wat about toe??
Old 12-22-2011, 04:57 PM
apexi_rsx's Avatar
yes they can adjust toe on the rear u have adjustments on the rear trailing arms.
Old 12-22-2011, 05:11 PM
swizz977's Avatar
ok can they asjust the toe in the front too??
Old 12-22-2011, 05:15 PM
TunerN00b's Avatar
Well, that answers that.
Definitely not trolling.
Old 12-22-2011, 05:46 PM
Markley02's Avatar
Using stock components they can adjust the toe and camber in the front. Just toe in the rear. You can get creative with washers to get more positive camber in the rear.
Old 12-22-2011, 06:24 PM
TunerN00b's Avatar
Wrong.
Only toe is adjustable. Every single Civic has been this way for the past 30 years.
Old 12-23-2011, 03:47 AM
Seagull Management
94EG8's Avatar
Originally Posted by TunerN00b
Wrong.
Exactly. I used to do alignments when I worked for Honda. The only thing you can adjust is the toe, if you need to adjust camber you need adjustable upper control arms.
Edit, forgot like half a sentence, makes sense now.
Old 12-23-2011, 09:00 PM
NotAJDMFanBoy's Avatar
You can get adjustable coilovers and when you adjust the ride height, it will affect camber. This is more if you're trying to gain negative camber, not adjust it like for an alignment.
Old 12-23-2011, 09:07 PM
ifIexplode's Avatar
This **** is just Lulz
houa-kage
Honda Civic (2006 - 2015)
10-29-2010 11:21 AM
huge230
04-08-2006 05:22 PM
2000turbosi
Suspension & Brakes
03-26-2006 08:24 AM
revolt_allmotor
Suspension & Brakes
11-06-2005 09:04 PM
01CWITR
08-06-2002 05:32 PM
Quick Reply: alignment question
