fully built 2.0 GSR blue smoke from exhaust
Old Dec 22, 2011 | 03:04 PM
boostfever's Avatar
Default fully built 2.0 GSR blue smoke from exhaust
my car had been sitting in the garage for over a year now since I was deployed. just recently changed the oil and coolant when I got back "sept. 2011" along with a new turbo kit. started up the car yesterday and notice alot of blue smoke coming from the exhaust
note: only one vacuum hose is hook up to the back of the intake manifold. nothing is hook up on the wg, bov and greddy bc and using rotella t 15w40 motor oil
Old Dec 22, 2011 | 04:25 PM
EsotericImage's Avatar
Retired Moderator
Default Re: fully built 2.0 GSR blue smoke from exhaust
im wondering if the rings took a crap since the car was sitting so long..
have someone drive the car and see if it burns when decelerating or both on accel and decel.
Old Dec 22, 2011 | 04:30 PM
Turbo-LS's Avatar
So it started smoking after the turbo install or just after sitting for the year? Could be many things
Old Dec 22, 2011 | 08:45 PM
boostfever's Avatar
motor has roughly 7500k miles since the built...could it just be burning off all the old oil that didn't get drain out?...motor sounds a little rough also but again no vacuum hose was hook up.
Old Dec 22, 2011 | 08:46 PM
boostfever's Avatar
just after sitting for a year in ky weather
Old Dec 22, 2011 | 10:13 PM
cibao2ner's Avatar
you probably just need to run it...for a while..maybe the oil control rings are stuck...do a compression and leak down test...and get it tune...
Old Dec 22, 2011 | 11:43 PM
rich7777's Avatar
x2, stick a few miles on it and see if it clear's up.
187Chor
Dec 6, 2007 02:45 PM
Nordy
Feb 24, 2007 07:40 PM
InJ3cted
Mar 31, 2004 07:46 AM
fxrob
Dec 12, 2003 03:59 PM
tonesdef
May 23, 2003 01:40 PM
