D16 Valve Cover Bolts?!?
Old Dec 22, 2011 | 01:14 PM
Dakota D16z6's Avatar
Default D16 Valve Cover Bolts?!?
Replaced the valve cover gasgets 2 days ago, popd the hood today and the 12m bolt was out! Oil EVERYWHERE! cant seem to find any online (even ebay didnt have em'!)
I live in Anna Texas, Anybody got some theyd sell/know of a store online that sells em?
My only other option is using Allthread bolts..
Default Re: D16 Valve Cover Bolts?!?
bump
Old Dec 22, 2011 | 01:18 PM
bump..
Old Dec 22, 2011 | 01:23 PM
grumblemarc's Avatar
The Grumpiest
Stop bumping the damn thread. You just posted.
Old Dec 22, 2011 | 01:26 PM
my bad bruh. thought you had to bump or the topic would drop down into the 2nm - 3rd page! New to Honda Tech, sry
Old Dec 22, 2011 | 01:28 PM
BryanM.'s Avatar
Resident Gearhead
Hard to find some stuff after market. Just get them from Honda, they're not too expensive.
>>> http://www.hondaautomotiveparts.com/...DER+HEAD+COVER <<<
EDIT: Actually they are expensive lol
EDIT 2: I'm out of this thread lol
Old Dec 22, 2011 | 01:31 PM
The Grumpiest
If someone comes along and has an answer they will respond to your thread. Have you tried contacting a local Honda dealership? Auto parts store?
Lol, thats what i was afraid of! would Allthread bolts work ok? im a little bit iffy about em'..
Old Dec 22, 2011 | 01:32 PM
Like Mcvtec said, there pricy! and my Uncle works up at Autozone and he said they dont carry them :/
Old Dec 22, 2011 | 01:43 PM
The Grumpiest
For piece of mind I wouldn't call that pricey.
Old Dec 22, 2011 | 01:48 PM
apexi_rsx's Avatar
are u talking about the 10mm bolts for the valve cover im sure i have some spare ones if ur looking for some. they are not 12mm though
Old Dec 22, 2011 | 02:04 PM
Are you just trolling my board??
Sweet! and there are 4 10mm bolts and one 12mm bolt on a Dseries Valve cover, but what would you be wanting for them?
Old Dec 22, 2011 | 02:13 PM
Didnt see that link lol, but the bolt im needing is one it isnt showing! its right above the hols for the plug wires.. right dead center of the cover!
Old Dec 22, 2011 | 02:14 PM
ddd4114's Avatar
Did you torque the bolts? Were the threads clean when you reinstalled them?
Old Dec 22, 2011 | 02:20 PM
My uncle tightend the 12mm bold even more after i did (i thought it was to tight but w/e lol) but only one of the 10mm bolts looked iffy, but its the one that freakn stayed in!! lol
Old Dec 22, 2011 | 02:23 PM
ddd4114's Avatar
Did you use a torque wrench or just guess?
Valve cover bolts are kind of important to actually torque correctly. Too loose and you'll lose oil, too tight and you'll lose threads.
Old Dec 22, 2011 | 02:26 PM
kaiba's Avatar
Valve cover bolt don't just fly/fall over. There's a possible chance that it was over tighten resulting in broken bolt.
Two guys with a wrench and a lil knowhow about cars.. we guessed! lol and ohhhh yes! im loosing a quart every few miles!! (found out while i was in town, then had to put a quart in just to make it home :/)
Old Dec 22, 2011 | 02:27 PM
guess ill go see if it broke! (didnt think of that..) Damn.. Brb guys
apexi_rsx's Avatar
12mm where? u sure your not talking about the rockers assembly...
Old Dec 22, 2011 | 02:35 PM
Ill have to w8 till tme so i can take off the valve cover to see if its broke..
And yea rsk, its the bolt above the 4 sparkplug holes (in the center of em')
ists shooting oil all over the hood/coresupport :/
Old Dec 22, 2011 | 02:50 PM
Wrona's Avatar
ur posts make my head hurt use a torque wrench next time stop guessing the bolts are 10mm not 12 idk where youre getting this 12 mm nonsense from i have pulled 4 d series motors, when i go to the junk yard i never have to use anything other than 12 only time i had to use a 12 on this car is when i was taking pedals off or some bigger hardware maybe thats why they are gone because u used the wrong ones
Old Dec 22, 2011 | 06:44 PM
redm3turbo's Avatar
isnt that #16 in the picture?
buck up and pay the 5 bucks.
Its going to cost 4x that to tap the broken nut out *if* your lucky enough to get it out (and if you did indeed break it)
and...get this
Old Dec 23, 2011 | 02:27 AM
The Grumpiest
That's what I'm saying.
Old Dec 23, 2011 | 03:18 AM
bradley's Avatar
Sounds like it was the entirely wrong bolt to start with, there are no 12mm headed bolts on the valve cover at all. Two long 10mm headed bolts in the back and three short 10mm headed bolts in the front. All self contained with rubber gaskets and washers.
Or on notec heads pre-Y7 you've got four 10mm nuts. On B series you've also got 10mm nuts.
I've never seen anything 12mm on a valve cover on any Honda four cylinder in my life.
