EG Electrical problem, headlights work but nothing else does
Old Dec 21, 2011 | 04:21 PM
Navy_CRX's Avatar
Icon2 EG Electrical problem, headlights work but nothing else does
Hi everyone...
Ive got a problem with my buddies EG coupe. long story short a friend of his "helped" him out by moving his car so it dident get towed and put it on a trailer and moved it for him. When they did it the wheel was locked so they ripped out the ignition to unlock the steering wheel. i just replaced the whole ignition assembly for him and we still have nothing. The headlights come on but it dosent do anything else, and i mean nothing. no turn signals no starter no windows its just dead. This is my first ignition ive done and im honestly stumped.
any help is greatly appreciated
Thanks in advance
Eddie
Old Dec 22, 2011 | 02:14 AM
Navy_CRX's Avatar
Default Re: EG Electrical problem, headlights work but nothing else does
Bump
Old Dec 22, 2011 | 03:44 AM
grumblemarc's Avatar
The Grumpiest
Was the car even running prior to relocation and the butchery done to it? Better locate some wiring diagrams and start checking your work. No way to tell what damage was done nor how you did the repair.
Old Dec 22, 2011 | 02:44 PM
Navy_CRX's Avatar
Car wasent running before i did the ignition but it at least cranked and the windows worked and what not. When i replaced the ignition i kinda feel like it was idiot proof due to it only having 2 plugs on it and they arent interchangable. We got it to crank with the bad ignition if we used a screwdriver to ground the tumbler and turned it with another screwdriver. At first i was thinking it might be a bad ground but i used my battery charger and jumped the small wire on the starter and it cranks fine.
Sorry about the ramble but im really stumped on it
Thanks in advance
Eddie
Old Dec 23, 2011 | 09:35 AM
Navy_CRX's Avatar
bump
Old Dec 23, 2011 | 01:19 PM
delsolo95's Avatar
manual or auto? the manual differs from the auto just saying..pics of install avail. sounds like something on the harness isnt correct if only the head lights work which means that the car isnt even in I or II postion.
Old Dec 23, 2011 | 01:27 PM
Navy_CRX's Avatar
Its a manual and i compared the two ignition plug wires and they are the same and hooked up in the correct spots
Old Dec 23, 2011 | 05:30 PM
delsolo95's Avatar
i didnt see this. the key tumbler has to be replaced then.. im not sure what your asking now. either the power doesnt turn on with the key turned or you cant get it to start bc you said it just cranks
STL7997
Honda Civic (2006 - 2015)
Nov 20, 2016 01:45 PM
alacard
Apr 3, 2009 01:50 AM
x4thGenCafe
Jan 5, 2008 08:54 PM
numbnuts22715
Aug 24, 2004 05:11 PM
User 5426
Aug 13, 2003 05:57 PM
