89 Civic SI Smog issue
Old Dec 21, 2011 | 10:29 AM
SI_Ro's Avatar
Default 89 Civic SI Smog issue
Attached is a screen print of 2 failed smog test reports. Here's a brief history of what has been done.
Bought this car around 6 months ago. Prior to that, it was sitting for a year (torn axle boots). I knew I shouldn't have, but I took it straight to the smog shop without tuning it up first. Failed with high CO% (0.63).
Tuned the car up after that (oil/filter change, air filter, fuel filter, spark plugs, spark plug wires, distributor cap/rotor, drained old gas, and added fuel treatment)....took it back to the smog shop and failed again...this time with a 24 BTDC ignition timing (probably advanced that high when I removed distributor).
The smog tech said that if I retard the ignition timing, sure it will resolve that issue, but will raise the CO%. Given that I barely passed the CO% at 25mpg, the tech said that I'd fail.
Anyone have any ideas on how to get this thing to pass?
Old Dec 21, 2011 | 10:36 AM
SI_Ro's Avatar
Default Re: 89 Civic SI Smog issue
Looks like the results on the attachment cant be read. The CO% on the 1st test measured at 0.63 with a 0.46 max. The ignition timing was 17 BTDC.
The Second test failed ignition timing at 24 BTDC and the CO% measured and passed at 0.40 with the 0.46 max.
These are what's circled/underlined in red.
BenjaminJeffers
Mar 4, 2014 04:01 PM
21ACEKING
Aug 9, 2012 09:49 AM
spermdoggy
May 25, 2012 06:20 AM
doubleoazn03
Apr 19, 2011 11:20 PM
niwisball3r
Mar 24, 2010 11:25 PM
