will I pass my smog check?
I drive an eg si, I recently changed my air filter, fuel filter, ignition coil, distributor oring, distributor cap, ignition rotor, o 2 sensor, spark plugs, valve cover gasket, seafoam the gas tank, seafoam the vacuum line, seafoam the crankcase, then changed the oil and oil filter. I also change my muffler to an ep3 muffler
after I use the seafoam, the engine started to idle a little higher, it also accelerates better.
I didn't change the cat because I didn't have enough money, do you think I can pass since I changed all of those things? Pecentage wise 80%?
Re: will I pass my smog check?
I barely passed last time with all my old stuff on, but since I changed everything out now, I should pass the test, yes?
spermdoggy
05-25-2012 06:20 AM
dem0nk1d
07-07-2006 11:11 AM
