crx ls swap smoking
Old Dec 20, 2011 | 09:16 AM
Wesleycrx1's Avatar
Default crx ls swap smoking
hey guys new to the forum. i have a 90 hf with a 94 ls swapped in and im having a big issue i swapped my intake manifold since i got a skunk2 for $50. problem is she's smoking big time and has a rough idle all my coolent lines are correct and in the right place. asking for idea's on what this may be.
Old Dec 20, 2011 | 09:29 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: crx ls swap smoking
Ok? What color of smoke? Did this happen before or after the intake manifold swap? What ECU? What OBD? Ect... Essentially stuff that can actually help us help you.
Old Dec 20, 2011 | 09:38 AM
EE2bitsk's Avatar
turd ferguson lol.
Old Dec 20, 2011 | 01:03 PM
Wesleycrx1's Avatar
white-ish blue color. it's obd-0 pr4 ecu tried a new ecu wasnt that.
Old Dec 20, 2011 | 01:07 PM
Dc4LsTeG's Avatar
EK9
Rings?valve seals?is it smoking on idle or just when you drive?how much smoke is it?
Old Dec 20, 2011 | 01:24 PM
Wesleycrx1's Avatar
smokes when i give it gas and its pretty good amount i mean it creates a cloud......has a rough idle too. smells rich as hell
Old Dec 20, 2011 | 01:25 PM
DO IT ON ALL FOURS
Sounds more like a blown headgasket. At least do a compression check or the likes...
Old Dec 20, 2011 | 03:36 PM
crvtectim's Avatar
Did you get your pcv valve and lines hooked up correctly after swapping the intake?
DnellM
Aug 17, 2013 11:10 AM
jdmson43
Jan 1, 2012 08:46 PM
boosh
Apr 22, 2008 12:13 PM
fitbmx86
Feb 29, 2008 05:59 AM
CivicSiR7
Dec 23, 2002 04:07 AM
