2005 Sport Keyless Entry
Old Dec 19, 2011 | 01:58 PM
Emereld's Avatar
Icon2 2005 Sport Keyless Entry
Hi all
I have my Sport from new and have had no issues.
Last year I was away from home with work . On my return I decided to get the Sport back on the road, the battery was dead and since it was the original from manufacture I fitted a new replacement, done a simple oil and filter change and inspection, turned over and running with no issues . Did a long drive with no problems.
Returned home and went to lock it but the fob did not respond so I locked it with the key for the night .
Next day opened the door, Alarm started and obviously the fob was not working, so sat into the car closed the doors/bonnet and went to reprogramme the fob (while alarm still active) using the usual method got to the point of the locks cycling/synchronization and alarm disarmed, then pressed lock on the fob and removed key from ignition to finish fob reprogramming .
Tried the fob but was unsuccessful . I completed the procedure several times to no avail . Also disconnected the battery for 20 mins to try reset memory and this failed to fix the issue.
I would really appreciate any light you, good people, could shine on this problem .
Thanks guys + girls
Old Dec 19, 2011 | 07:33 PM
toyomatt84's Avatar
Sanji
Default Re: 2005 Sport Keyless Entry
Sport? Is this a hatchback you're referring to?
Old Dec 20, 2011 | 01:21 AM
Emereld's Avatar
That's it 3door Hatch, sorry.
maryellenwalter
Honda Civic (2006 - 2015)
Oct 28, 2023 05:40 AM
chriskinlaw
Dec 29, 2018 04:25 PM
menappi
Audio / Security / Video
Nov 18, 2006 01:32 PM
95 Gizzer
Mar 27, 2003 05:44 PM
