ef ls swap wiring
hey im trying to wire my ls into my 91 si hatch. i have obd1 ls with the obd1 ecu and jumper harness. the engine harness connectors dont match the ones in the car. what do i need for them to connect?
Unless you want to deal with a wiring NIGHTMARE - use your factory harness and adapt it as necessary. Everything you need to know is in this link...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
Ya I found out last night I need the si harness and obd0 ls dizzy. And pr4 ecu. How do I convert my obd1 or 2 dizzy (have both) to obd0 so i dont have to buy another one?
you can not convert obd1 or 2 to obd0 i had the same issue and the obd0 distributor runs the injectors where as the obd1 and do not so you will have to get a harness to distributor jumper and use the factory obd0 harness
all in all
obd0 to obd1 ecu jumper
obd0 to obd1 distributor jumper
obd1 ecu
obd1 distributor
you have to match the ecu to the distributor
all in all
obd1 ecu
obd1 distributor
So the car came with the ecu jumper. But it had lsv in it, the kid blew it up and did an ls swap. So can I still use the jumper with my odb1 p75 instead of buying a pr4? Or will the favt he ran vtec on it before make it not work for the ls?
u need
obd0 to obd1 dizzy jumper harness
if ur running the obd1 alternator then u need the obd0 to obd1 harness for that
and use crx si injectors ( i dont know what the guy above is talking bout mine fit perfectly)
use rywire.com for the harnesses. great products
As for the previous guy, he is correct about fitting obd0 injector plugs on obd1 injectors. There are 2 small tabs that need to be trimmed on the plugs to fit into obd1 injectors. OP, if you do run obd1 injectors make sure to also do a resistor box delete.
u are correct by bad i was swaping a b20 in a crx witch came with the obd2 alt.
delsol92 said u have to trim obd0 injectors which is wrong if he is using his stock ef harness. the easiest way for me was to get obd0 si injectors which i didnt delete the resistor box and didnt have to rewire the the plugs to obd1 or like u said i guess u could trim them
ComeOnKip
Jan 28, 2009 01:04 PM
HtC_SiR
May 26, 2004 12:11 PM
