VX Partial Throttle Flat Spots.. yes yes again
Well I really hate posting this because it seems everyone has issues with the hesitation, lean burn condition, etc etc. So:
I have done:
Plugs
Wires
Cap
Rotor
Seafoam
Replaced Fluids
Fuel filter
The throttle cable does not need adjusting
What I have not done:
Checked ALL grounds
Clean EGR
Timing
Fuel pump
Injectors
Cleaned throttle body
So at part throttle my car drives like crap, hesitations and just plain flat. My 02 sensor looks fairly new and it is made by NTK, so I should be ok in that area...BUT, when I disconnect the O2 Sensor, the car drives perfect. So I am a bit puzzled. I do not have a check engine light when the sensor is connected. The sensor seriously looks new...
In any case... this is pretty frustrating, I bought the car for cheap, but the person before me did not take of it at all. I got the car at 10% running and I am at about 90% after all the work I have done.
Thanks.
I have done:
Plugs
Wires
Cap
Rotor
Seafoam
Replaced Fluids
Fuel filter
Checked ALL grounds
Clean EGR
Timing
Fuel pump
Injectors
Thanks.
Updated.
I am going to try and get some of the simple things done on the weekend. The car has power, it is just really odd down low at part throttle.
Did you mean new injectors or cleaning them.
Your kidding right. Yea I have a road race car that I use at vir. I am well aware of how the civic should be driving. I think I was pretty clear on the issues I am having as many have had the same issue in the past.
si del sol 94
18
Sep 16, 2009 07:39 PM
benjamin80
Honda Civic (2001 - 2005)
Sep 23, 2008 10:22 AM
