95 civic ex help ASAP!!
Old Dec 18, 2011 | 03:12 PM
Honda24noobish's Avatar
Default 95 civic ex help ASAP!!
My 95 civic ex is rev limiting at 3k on the nose. It's popping cel code#4 which is the crank position sensor. I need some advice on how to fix and save money! Please educate my noob self
Old Dec 18, 2011 | 03:28 PM
D16SiHatch's Avatar
Default Re: 95 civic ex help ASAP!!
Swap a known functioning distributor in and see if the problem goes away. the CPS is within the dist.
Old Dec 18, 2011 | 03:58 PM
so if i replaced the whole dizzy a little over a year and a half ago and another piece of it has gone bad should i look into something else?
Old Dec 18, 2011 | 07:31 PM
EJ8_Man's Avatar
If the Dizzy was replaced with a known stock OEM working replacement it could be a wiring issue. Have you modified the stock wiring harness?
Old Dec 19, 2011 | 09:12 AM
No but upon retrieving the cel code I noticed that the wires leading my jumper harness behind the glovebox match up with the ek's rather eg. Idk I'm lost on what was going on with my car prior to me owning it
Old Dec 19, 2011 | 09:16 AM
EJ8_Man's Avatar
Is your motor a D16Z6 or D16Y8? The stamp is on the front of the engine block to the left of your exhaust manifold.
Old Dec 19, 2011 | 09:20 AM
grumblemarc's Avatar
The Grumpiest
Maybe you better list off everything that you know about the car. Including engine, ECU, etc.
Old Dec 19, 2011 | 09:23 AM
EJ8_Man's Avatar
Yeah also note if it's got a conversion harness or if it's using the stock wiring harness. You said jumper harness which sounds like conversion harness. If that's the case my bet is the harness has a faulty connection, which you can fix, but it will take time to hunt down the correct leads and re-solder them
Old Dec 19, 2011 | 12:23 PM
JgDsMr's Avatar
cam/crank codes might pop up and they could be the opposite sensor. the ecu will just compare the two cam/crank and throw whatever code it wants cam or crank if they dont match up correctly. just be aware that it could be either one.
Old Dec 23, 2011 | 11:13 AM
D16z6 won't revv over 3k once hot. Loss of power and none if down shifted into lower gear and Rpms are over 3k . Idk I'm lost on this problem.
Old Dec 23, 2011 | 11:41 AM
Everything is stock except for the dc headers and o2extender from pwjdm also a dynomax exhaust. 5sp 200+on the odo around a buck20 on the engine I was told had been rebuilt. Second dizzy wasn't Honda but met oem specs. Also a hefty gas smell comes off the car from time to time. I haven't been able to figure out the cause of that yet
Hondamonster
25
Apr 1, 2022 12:23 PM
nkuser
Nov 20, 2020 08:36 PM
dizzledude
Oct 4, 2008 06:03 PM
colt45.5
Jan 6, 2004 02:41 PM
