97 Accord RPM fluctuation issue
I have a 97 Honda Accord SE with a 2.2L SOHC engine.
The issue is with (like stated in the title) RPM fluctuations. The RPM needle begins to move wildly after a certain point of pressing down the accelerator. This usually occurs around 3K RPMs or 75/80 mph. If I don't press the accelerator hard and keep it normal under normal driving conditions, the RPMs are fine. It happens about after the pedal is pressed half-way down.
Any ideas? Also, one other thing the car has: while idle, the engine knocks (not a huge knock it's more of a big tremble than knock.) Thanks for the responses!
Last thing though, I noticed there is a small burn on the ECM. I bought a new (used) one that is coming in on Tuesday. I will update Tuesday when I install the ECM, but for now please give suggestions as if the ECM was fine.
Thanks for your reply, anyone else have any ideas? It turns out the computer was sent to a different address, and is being forwarded to my current address. I'm going to have the car taken to a mechanic to check all whatever you suggest (including checking the TPS), unless there are only a couple things to check that I can do by myself.
SporeVenom
Dec 30, 2011 07:34 PM
SporeVenom
Nov 16, 2011 03:14 PM
lonestar
Aug 1, 2002 12:23 AM
